Hello everyone, I have a question that has been on my mind for a while: I own an IKEA Metod kitchen and would like to replace the drawer fronts myself, as having a company do the installation has become quite expensive, and I am reasonably skilled with DIY projects. My specific question is: Is it technically and mechanically possible to replace the drawer fronts or complete drawers of the Metod series on my own without much effort? Are there common pitfalls to watch out for, especially regarding the hinges, drawer slides, or fastenings? I would appreciate any tips or personal experiences.
FRANCISCOP2 Oct 2021 17:55Nielsmin schrieb:
Is there a special tool or aid that is necessary or helpful?The IKEA Metod fronts are designed so that adjustment can be done with a simple Phillips screwdriver. The mounting brackets on the drawer front have adjustment screws that allow you to align the front in all three axes (horizontal, vertical, and depth). It is important to adjust the fronts step by step and repeatedly check that they close properly. No special tools are strictly required; a good screwdriver is sufficient. For precise results, a spirit level can be helpful to avoid major misalignments.
One small tip from my own experience: before fully screwing on the new front, check if the soft-close function of the drawer works smoothly by opening and closing it several times. This way, you can make any necessary adjustments before the final installation and save yourself from rework.
The discussion here is very helpful, especially because the difference between front replacement and full drawer installation is often overlooked. I would add that in older Metod kitchens, the mechanisms can loosen over time. In such cases, it is often more worthwhile to replace the entire drawer with the rail instead of just changing the front.
benfa schrieb:
in older Metod kitchens, the mechanisms can wear out over time.That is correct and an important point. Replacing the front does not solve this issue. If you notice that the drawer no longer slides properly or sticks, the only solution is to replace the drawer slides or the entire drawer runner system. IKEA still offers spare parts for this, but you should pay attention to the model year, as the systems vary. Consulting the assembly instructions for the corresponding year can help clarify this.
Thanks to everyone for the great and detailed responses. It has become clear to me that replacing the IKEA Metod drawer fronts is generally doable as a DIY project, but there are several variables depending on the size, the existing condition of the hardware, and the quality of the replacement fronts. I especially appreciate the advice on adjusting the fronts and the recommendation to use original parts. I will proceed step by step with the installation and document the process carefully.
