ᐅ Is it possible to extend an Ikea Brimnes wardrobe by myself?
Created on: 8 Mar 2019 10:37
fonetan
fonetan
8 Mar 2019 10:37
I am considering expanding my Ikea Brimnes wardrobe myself to adapt it to my growing storage needs. My question is: Is it generally possible to extend the Brimnes wardrobe on your own, for example by adding extra components like shelves or widening it with matching modules? Are there specific procedures or limitations I should be aware of, such as stability, compatibility of screws and materials, or the assembly instructions?
Since I am fairly technically skilled, I plan to do this as cleanly and permanently as possible, but I want to avoid any mistakes that could later lead to an unsafe piece of furniture. Has anyone had experience with this or can offer advice on how to sensibly and safely expand such furniture independently?
I look forward to your assessments and suggestions!
fasau
8 Mar 2019 11:05
fonetan schrieb:
Is it generally possible to expand the Brimnes wardrobe yourself, for example by adding extra elements like shelves or increasing the width with matching modules?
Absolutely! I expanded my Björn wardrobe (similarly sturdy to the Brimnes) myself by installing additional shelves. You just need to measure carefully and use the right screws. It’s important to keep an eye on stability—using extra brackets for reinforcement and making sure everything is securely screwed together is best.
My advice is: go for it! With a bit of DIY skill, it’s definitely doable. Increasing the width is a bit trickier, but with suitable wooden boards as an interim solution, you can manage that too. Good luck, and let me know if you need any help!
ladali
8 Mar 2019 13:21
fonetan schrieb:
Are there any special procedures or restrictions I need to consider, such as stability, compatibility of screws and materials, or the assembly instructions?
Expanding an Ikea Brimnes wardrobe is possible, but there are clear limits and system-related constraints:
- The Brimnes wardrobe is designed as a single unit, already pre-drilled and doweled, which makes extension difficult.
- Shelves can be added within the existing grid if appropriate shelving boards and brackets are used.
- Changes in width or height through additional modules are not directly supported. In such cases, you would either need to place double constructions side by side or create custom builds.
- Screws and materials should match the original parts to ensure material compatibility and stability.
My advice: If an expansion is unavoidable, first check the load specifications in the assembly instructions. Also, find out whether IKEA offers modular compatible elements that you can attach centrally or laterally without major modifications.
In summary: Expansion with original parts within the system is limited; everything beyond that requires craftsmanship experience and is done at your own risk.
jelite
9 Mar 2019 09:47
Regarding the topic "Independent extension of the Ikea Brimnes wardrobe," I recommend the following approach if you want to add shelves:
1. Measure the existing drill holes precisely, as the Brimnes has a standardized row of holes. The additional shelves must fit exactly into these holes; otherwise, the whole structure will become unstable.
2. Obtain suitable shelf supports, ideally the same type used by IKEA, to avoid compatibility issues.
3. If you want to expand the width or height, you cannot simply attach more modules without destabilizing the system. In this case, sturdy intermediate frames made from plywood panels or angle brackets are helpful.
4. Work step by step and check the stability after each stage, as even small deviations can cause IKEA furniture to tip over easily.
5. Ensure that all components are securely screwed together and that the back panel is fully fixed, as this greatly improves stability.
Common mistakes include neglecting the back panel and using inappropriate screws. You can avoid these by following a structured approach.
If you like, I can put together a rough guide with example steps for you.
BAUEVA
10 Mar 2019 16:12
jelite schrieb:
If you want to increase the width or height, you can’t just attach additional modules without destabilizing the system.
That hits the mark. IKEA furniture like the Brimnes is designed for a specific static load and fixed construction. Even adding extra shelves or modules fundamentally changes the load distribution. Without structurally tested reinforcements, you risk deformations or a significantly reduced lifespan.
Unfortunately, IKEA lacks a modular expansion solution for such cabinets, so “do-it-yourself” modifications can compromise safety. If expansion is essential, I recommend either:
- Using compatible IKEA modules as standalone units placed side by side.
- Custom builds using sturdy materials, but designed completely from scratch.
The whole process should be carefully planned and ideally structurally tested if it’s more than just shelving adjustments. A “simple” expansion is not straightforward.
