Haydenja5928 May 2024 21:13Hello everyone, I am currently considering whether I can modify my IKEA Pax system to create a walk-in wardrobe. I am thinking of placing several Pax units side by side or arranging them in a suitable room niche to basically form a small dressing area with storage and enough space to move around. Does anyone have experience with this or any tips on the best way to do it? I am especially interested in how to make it stable and visually appealing, which additions are recommended, and whether it makes practical sense to repurpose IKEA furniture for such a purpose. Thanks for your input!
Yes, that is generally possible. It is best to connect the Pax wardrobes using bridging elements, such as shelves or sturdy wooden panels. It is important to ensure sufficient depth and height to allow for movement. You can replace the doors with sliding doors to save space.
Hello Haydenja59, I’ll try to give you a more comprehensive overview: A Pax system can definitely be converted into a walk-in closet solution, especially if you have a niche that is wide and deep enough. There are a few points to consider:
- Stability: Multiple wardrobes need to be securely connected, ideally with brackets or clever connectors from the inside.
- Access: Sliding doors or open shelving are often more practical for a walk-in version than hinged doors.
- Use of room height: You can connect the Pax units with an upper frame base or stabilize everything with a ceiling panel.
- Interior fittings: Use accessories like clothes rails, drawers, and baskets to increase functionality.
It is also important that your space allows enough room to move around, so a minimum aisle width of 80 cm (31.5 inches) is recommended. Careful planning before assembling is advisable to avoid buying the wrong items.
What dimensions and room conditions are you basing your plan on? That could help provide more specific advice.
Haydenja5929 May 2024 11:45klo61 schrieb:
What dimensions and room conditions are you basing your plan on? That might help provide more precise advice.Thank you for the detailed answer! My space is a niche approximately 220 cm (87 inches) wide, 150 cm (59 inches) deep, and 250 cm (98 inches) high. I was thinking of placing two or three wardrobe units with a depth of about 50 cm (20 inches) each side by side, possibly creating a corner unit or an “L-shape” to form a small dressing area that remains accessible without feeling cluttered. Due to the height, I want to make full use of the space, preferably with built-in shelves or drawers at the top that I don’t need to access daily. I’m just unsure whether these types of wardrobes are sturdy enough for a long-term solution and how best to screw the individual modules together so the entire setup doesn’t wobble. I am also considering whether I should reinforce the side panels.
Your idea sounds basically feasible. The Pax system is sturdy, but for a walk-in wardrobe, the way the modules are connected is crucial. I recommend:
- Use additional corner brackets at the corners and between the units.
- Reinforce side panels if necessary with thin plywood sheets or battens for added stability.
- Plan for an assembly method with an external base plate or a light anchoring to the walls – this will secure the system.
With a height of 250 cm (98 inches), you can work with the top shelves to optimize storage space. If you replace the doors (sliding doors or modular open units), it will feel more open and walk-in friendly.
Keep in mind that using a carpet or a small rug can also make the space more comfortable and functional.
If you like, I can also give you tips on interior organization that fits very well in a walk-in Pax wardrobe.
