ᐅ Is it possible to assemble IKEA PLATSA shelves without the back panel?
Created on: 15 Jul 2021 09:23
kaleix
kaleix
15 Jul 2021 09:23
I am considering assembling my IKEA PLATSA shelving unit without the included back panel. My main question is: Can the PLATSA units be built without the back panel without losing stability and rigidity?
I find it more visually appealing and intend to use the shelving as a room divider, so an open back would be an advantage. Does anyone have practical experience or recommendations regarding whether omitting the back panel is safe, or if it might cause issues with load-bearing capacity or resistance to twisting?
Thanks in advance for your insights!
Hannes
15 Jul 2021 09:48
Yes, you can assemble the PLATSA shelves without the back panel. However, this will make the shelf less stable and it may be more prone to twisting. If you want to use the shelf as a room divider, I recommend securing it to a wall or using additional stabilizers.
Ramon4
15 Jul 2021 10:05
Hello kaleix,
Regarding the basics: IKEA PLATSA shelves are modular, and the back panel actually plays a major role in stability. Without the back panel, the lateral stability is missing – the shelf can twist or tip over more easily.
If you want to omit the back panel, make sure that
- the shelf is secured to the wall (e.g., with brackets),
- you add additional reinforcements if necessary,
- and the load is distributed evenly and not too heavy.
In conclusion: It is possible, but it does not provide the full stability that would be given with the back panel.
Linavin
15 Jul 2021 10:37
Hannes schrieb:
Yes, you can assemble the PLATSA shelves without the back panel. However, the shelf will be less stable and more prone to warping.
That is true, but I believe it’s important to be more precise here: When assembling the PLATSA shelves without the back panel, you don’t just lose stability—you also compromise safety, especially in homes with children or pets.
Without the back panel, you lose a critical diagonal reinforcement that prevents the unit from tipping over. As a result, the shelf becomes more vulnerable to damage unless it is secured in another way.
So, the back panel should not be omitted for purely aesthetic reasons without considering alternative safety measures.
Lotizar
15 Jul 2021 11:14
I would like to add some facts about the construction of the IKEA PLATSA shelves:
- The back panel functions as a diagonal brace that keeps the frame structure of the shelf rigid.
- Without it, the tendency to twist under load increases significantly.
- The assembly instructions recommend always installing the back panel unless alternative stabilizations are used.
Therefore, if the back panel is not used, it is essential to secure the unit to a wall or floor to prevent accidents and material damage.
kemads46
15 Jul 2021 13:22
Brief Guide for Assembly Without a Back Panel:
1. Assemble the frame according to the instructions.
2. Omit the back panel for now.
3. Ensure the shelving unit can be securely fixed to a wall – this prevents tipping.
4. Optional: Attach additional corner brackets or metal profiles to the sides to increase stability.
5. When loading, make sure there is no uneven weight distribution on one side.
Common Mistakes:
- Leaving out the back panel and placing the shelving unit freestanding.
- Insecure attachment, which leads to risk of tipping.
If you keep these points in mind, it is possible to assemble without the back panel, but from a safety perspective, it is not ideal.
