ᐅ Is it possible to assemble IKEA PLATSA furniture without a back panel?
Created on: 16 Nov 2022 19:37
Marvinche0
Marvinche0
16 Nov 2022 19:37
I am planning to install IKEA Platsa shelves in my home office, and I am considering assembling them without the included back panels. My main question is: Is it technically and structurally possible to build IKEA Platsa furniture without the back panel without losing stability or making the units prone to tipping? I intend to place the furniture against the wall, but I find the back panel visually unappealing since it would be visible in my setup. Could anyone provide additional information, for example, how important the back panel is to the overall structure, or whether alternative solutions can be used without compromising stability? Thank you in advance!
Joshbe
16 Nov 2022 20:24
The back panel in IKEA PLATSA furniture primarily serves to stabilize the unit and prevents the frame from tipping or twisting. Without the back panel, the structure loses significant stability since the side panels alone do not provide sufficient torsional rigidity.
While it is possible to fix the furniture to a wall, back panels are generally designed to stabilize the overall frame. One way to avoid using the back panel is to install stabilizing brackets or shelf supports on the sides or back, which can also be mounted separately.
Alternatively, some users recommend cutting and painting back panels from thin plywood or veneer if the appearance is a concern. This keeps the rigidity intact while allowing customization of the look.
In short: technically, it is possible to omit the back panel, but without additional measures, the furniture will not remain sufficiently stable.
teyosef
17 Nov 2022 08:42
In addition to what Joshbe has already mentioned, here is a structural overview:
- Function of the back panel: It firmly connects the side panels and provides cross-bracing reinforcement that prevents twisting and tipping movements.
- Construction without a back panel: Possible if other reinforcements are installed, such as metal brackets, crossbars, or by adding a different solid panel on the back.
- Wall mounting: Secure wall fixing can partly compensate for the missing back panel, but the anchors and screws must be suitable for the type of load and wall material.
- Visual alternatives: Instead of a bulky back panel, a thinner, coated or painted wooden board can be used, precisely cut to size.
Common mistakes when omitting the back panel include skipping the wall mounting or ignoring the stability guidelines provided by IKEA, which can lead to unstable furniture and potential safety hazards.
I would recommend carefully planning the intended wall mounting and any alternative reinforcements before deciding to leave out the back panel.
meoreo
17 Nov 2022 14:09
Joshbe schrieb:
The back panel in IKEA PLATSA furniture primarily serves to stabilize and prevents the frame from tipping or twisting.
... and without a back panel, sturdy brackets must be used for reinforcement. Mounting to the wall alone is usually not sufficient.
