ᐅ Is it possible to assemble Ikea Pax wardrobes without the bottom panel?
Created on: 15 Aug 2024 10:37
neokla3
neokla3
15 Aug 2024 10:37
I am currently facing the challenge of assembling an Ikea PAX wardrobe, but due to space constraints and some structural conditions, I am considering whether it is generally possible to assemble and use the wardrobe without the bottom panel (i.e., the lowest base panel on which the drawers or shelves usually rest). My specific question is:
Can I safely and securely assemble the Ikea PAX wardrobe without the bottom panel without compromising stability, functionality, or the warranty? Are there particular points to consider or risks involved, for example regarding load-bearing capacity, twisting, or the usability of the drawers and shelves?
I would greatly appreciate any experience reports or detailed information about the consequences of omitting the bottom panel, as I might need to adapt the construction in my space but want to do so without sacrificing the furniture’s quality.
Thanks in advance for your expertise!
ju_ren
15 Aug 2024 11:12
In short: The baseboard is part of the main structure of the PAX. Without it, stability is significantly compromised. I would advise against it, especially if drawers are included.
There is no official recommendation from Ikea for installation without the baseboard, and this can lead to tipping hazards or damage.
Ramon4
15 Aug 2024 12:45
Hello neokla3,
Basically, with an Ikea PAX wardrobe, the bottom panel serves a load-bearing function. It connects the two side panels and contributes to the overall stability. If you omit the bottom panel, there is a risk that the frame becomes unstable, twists, or in the worst case, the lower connection might fail.
Another important point is that the drawers or shelves, which normally rest on the bottom panel, cannot be properly installed or used without it.
If you really don’t have space for the bottom panel, you could try to ensure stability by adding extra reinforcements in other areas, such as brackets or metal braces. However, this would be a custom modification and no longer within Ikea’s official guidelines.
If you are interested, I can gladly give you advice on how to plan such reinforcements effectively. It is important to keep the wardrobe’s weight and usage in mind – the bottom panel is not just a decorative element, but part of the structural integrity.
Best regards!
Dilen
16 Aug 2024 09:04
Hello neokla3,
I would like to provide a more detailed response, as this topic requires some technical background knowledge.
The Ikea PAX frame is based on a modular system, where the base panel is considered an integral part of the overall stability. Functionally, it connects the side panels at the bottom and prevents them from spreading apart or warping. This is especially important because the wardrobe often supports several dozen kilograms (pounds) of weight—whether from clothing, drawer contents, or shelves.
If you remove the base panel, the load distribution changes significantly. On the one hand, the horizontal connection responsible for side stability is missing; on the other hand, drawers that normally rest securely may no longer have a firm support. Additionally, the lower drawer slides are usually designed to work with the base panel—without it, functionality can suffer considerably.
I would recommend carefully considering the following points before removing the base panel:
- How is the wardrobe loaded overall? Are there heavy drawers or baskets inside?
- Is the wardrobe placed on a fully level and load-bearing floor?
- Is it possible to replace the missing base panel with an alternative rigid connection (e.g., metal brackets, glued wooden strips)?
You should also keep in mind that modifying the structure usually voids the official Ikea warranty, as the furniture no longer complies with the intended assembly instructions.
If you’d like, feel free to provide more details about your situation here, and I can help assess it and offer tips on how to best address it.
Dilen
Nabla64
16 Aug 2024 16:22
Dilen schrieb:
The Ikea PAX frame is based on a modular system where the base panel is considered an integral part of the overall structural stability.
I would like to add: Anyone building their PAX without the base panel should always perform a simple stability check after assembly before fully loading the wardrobe. This includes:
- Standing the wardrobe upright, gently rocking it from side to side to check if the lower part of the structure wobbles
- Checking the drawer runners for secure fastening
- Ensuring there is no noticeable stress on the screw connections
If there are any doubts, special angle brackets or connector plates can be used for reinforcement. A frequently overlooked method is to cut a thin, sturdy MDF panel to fit exactly into the base of the frame instead of the original base panel, which helps maintain fundamental stability even when space is limited.
Therefore, anyone wanting to omit the original base panel should not simply leave it out, but rather create a functional alternative.
In summary, while a PAX construction without the base panel can save space in the short term, it is not suitable for long-term use without appropriate reinforcement.
