ᐅ Is it possible to assemble Ikea Besta units securely without using the original screws?
Created on: 15 Sep 2024 09:37
Editra
Editra
15 Sep 2024 09:37
I have a rather specific question: I own an Ikea Besta shelving unit that I am about to assemble. Unfortunately, I am missing the original screws because I bought the furniture secondhand, and the previous owner apparently did not include them. My question is: Is it possible to assemble the Ikea Besta securely and stably without the original screws?
I am not only concerned about basic stability but also whether alternative screws are truly comparable in terms of material quality, size, and functionality, so that the furniture remains durable and does not lose stability. Additionally, I am interested in any recommendations for suitable screws if the originals cannot be used.
I know Ikea often uses special fasteners, so it is important to me not to make compromises that could lead to an unsafe structure later on.
I would appreciate it if someone with experience or expertise could provide their insight!
fredle
15 Sep 2024 10:12
Hello Editra,
First of all, that’s a practical and precise question! Ikea Besta indeed uses specific fasteners, primarily the so-called Minifix connectors and screws with special thread pitches and heads.
I recommend the following approach:
- Avoid using just any screw from a hardware store, as the length and diameter usually don’t match exactly.
- Pay attention to the original dimensions: these are typically wood screws with a diameter of 4 or 5 mm (0.16 or 0.20 inches) and a length of about 30 to 50 mm (1.2 to 2.0 inches), depending on the connection point.
- Alternatively, you can get Minifix sets or spare parts directly from Ikea or specialized furniture hardware stores—often cheaper than buying a completely new unit.
A stable connection is only guaranteed if the screw material has sufficient strength, ideally steel screws with a good surface finish (e.g., galvanized).
Additionally:
- Use a suitable screwdriver to insert the screws cleanly and avoid damaging the threads.
- Always check if the connections are tightened firmly but avoid overtightening, as this can cause the wood to crack.
In summary: Yes, you can assemble the unit without the original screws, but only if you use matching replacement parts with exact dimensions and quality; otherwise, the stability will be significantly compromised.
blapau
15 Sep 2024 11:05
I would like to add that the connection points in Ikea Besta are sometimes designed so that only combinations of screws and Minifix connectors fit and hold properly.
Simply using alternative screws without these connectors can affect the load-bearing capacity.
If the original parts are not available, it is worth paying close attention to the type of connection. If necessary, you can purchase suitable Minifix connectors separately and combine them with appropriate replacement screws.
The type of wood used also plays a role in how the thread is held. Cheaper screws can damage the wood or become loose.
My advice: quality is more important than quantity here if safety and durability are desired.
BARSAN
15 Sep 2024 12:23
In short: No, not just any screw will do. Only use screws with the correct diameter and length. Original parts or equivalent replacement screws plus Minifix connectors are required. Otherwise, the shelf will be unstable.
Davidleo
16 Sep 2024 08:47
It’s very important not to skimp on screws! I once tried to assemble my Besta with standard screws, which was a mistake – after a few weeks the unit started wobbling, and I had to redo everything with the correct screws.
Pro tip: When in doubt, it’s better to buy replacement screws directly from Ikea or look for high-quality furniture screws at the hardware store.
It’s worth it to keep the shelf stable and avoid frustration! Good luck!
fredle
16 Sep 2024 09:15
Davidleo schrieb:
I tried to assemble my Besta with standard screws, which was a mistake – the unit started wobbling after a few weeks
This matches my experience: the tolerances at Ikea are quite precise. Even slightly different screws can cause the joints not to fit properly.
So here is a brief checklist for replacement parts when assembling without the original screws:
- Measure screws exactly for length and diameter
- Use at least steel (no aluminum or brass alternatives)
- Use the correct head type (cross-slot, sometimes hex socket)
- Check and, if needed, get the Minifix connectors separately
- Screw in slowly and carefully, avoid over-tightening
If you follow these points, your assembly should be stable.
