ᐅ Is it possible to repair IKEA PLATSA furniture myself if parts break?
Created on: 26 Oct 2022 14:23
enes68Hello everyone, I have several IKEA Platsa modules in my apartment, which I really appreciate for their flexibility and modular design. Unfortunately, a part of the upper side panel on one of the shelf inserts recently chipped off, and I’m wondering if these PLATSA furniture pieces can be repaired by myself in case of damage.
I’m particularly interested in:
- How sturdy are the individual components of PLATSA, and how repair-friendly are they designed?
- Can replacement parts be easily purchased, or do you need special tools and techniques to fix damages?
- Are there any proven methods or tips for repairing breaks in the wood panels or joints without having to replace the entire module?
Since I’m fairly handy, I’d like to avoid expensive repair services if possible. I’m looking forward to your experiences and advice!
Hello enes68, you can handle repairs on IKEA PLATSA yourself quite well if you have a bit of patience and the right tools.
First of all, the PLATSA modules are made from relatively thin engineered wood panels, often coated with melamine or foil – this makes them lightweight but also somewhat sensitive to mechanical stress. Breaks usually occur at the joints, especially along the edges or in areas where bolts and dowels are inserted.
For repairs, the following steps are recommended:
- Carefully sand the damaged areas to smooth out rough spots.
- Small cracks or chips can be filled with wood filler or wood glue and then sanded.
- For larger breaks, you can reinforce the area with small wooden panels (e.g., plywood) attached from the inside to the backs or similar parts, glued or screwed in place without affecting the furniture’s external appearance.
Replacement parts like side panels or shelves can usually be purchased from IKEA, if still available. It’s worth ordering these with the exact article number. IKEA does not sell small repair kits for PLATSA, as this series is designed to be modular and affordable, favoring replacement over repair.
If you want to disassemble the furniture, be careful with all screws and connecting parts, as they tend to be delicate. It becomes trickier if the coating is extensively damaged – in that case, renovation films can be used, but this increases the effort involved.
In summary: Yes, you can definitely repair PLATSA yourself if you are handy. Many damages can be fixed with simple tools, although this does not always perfectly restore the original look, especially in the case of visible scratches.
Bagupo schrieb:
I have already repaired minor damage to PLATSA myself. Usually, wood glue and clamps help. Spare parts at IKEA are relatively easy to get. You don’t need anything more.I would agree with that.
The PLATSA series is basically designed so that replacing individual components is the most common repair method—especially when it comes to structural damage that cannot simply be glued or filled.
Wood glue is the right choice for clean break surfaces that fit well together, particularly for edges or inner panels. You should make sure to clamp the parts firmly during drying to achieve the strongest possible bond.
If larger parts like side panels are damaged or stability is compromised, it’s advisable to replace the affected modules. IKEA generally has a well-organized spare parts service, especially since PLATSA has only been on the market for a few years.
In terms of tools, you don’t need much—a cordless drill with the right bits, wood or PVA glue, clamps or quick-release clamps if needed, and fine sandpaper are usually sufficient.
As a side note: for highly visible areas, pay particular attention to cleanliness when gluing damaged surfaces (clean workspace) and consider color matching if the damage is still noticeable.
In short—repairing is doable and IKEA supports spare parts, but not every defect can be fixed with glue; sometimes a full replacement is the better solution.
