ᐅ Is it possible to adapt Ikea Metod cabinets to sloped walls?
Created on: 4 Mar 2024 10:03
Dietmarpin
Hello everyone, I am currently planning to install Ikea Metod base cabinets in a room with sloped walls (pitched roof). My question is: Is it possible to adapt the Metod cabinets to these angled walls without making the installation unstable or causing visual defects?
Are custom cuts to the sides or special mounting methods possible to compensate for the slope in a neat way? I would appreciate any tips based on your experience, as well as advice on the necessary tools and materials if you have already done this.
Another experience from me: if you are already beveling the countertop (or buying it pre-shaped), you can visually compensate for the slope this way. This makes the cabinets appear straight, and the slope becomes less noticeable.
Customizing the countertop is more expensive but makes sense for better harmony in the room.
Summary:
- Directly cutting the Metod carcasses to fit sloped walls is not recommended for stability reasons.
- The best solution is to place the cabinet vertically and close the gap between the cabinet and the wall with filler strips or panels.
- These panels should match the material and appearance of the cabinet front.
- Stability is ensured by secure attachments to the floor, back wall, and ceiling.
- Important: Plan the workflow and storage space carefully to avoid unnecessary gaps that reduce usable space.
A question for Dietmarpin: Are you planning the cabinets as base units only, or should wall cabinets also be considered for the slope?
This partially affects the approach, as wall cabinets require different mounting and more visual adjustments.
Dietmarpin5 Mar 2024 13:30Thanks to everyone for the many tips.
I only want to install base cabinets, no wall cabinets, but the space is quite small, so every centimeter (0.4 inches) counts. I might try using panels that I have custom laminated to fit.
The countertop will be a custom size anyway, as the slope plays a role.
I’m also interested if anyone has experience with screws or brackets specifically used for mounting on sloped ceilings—preferably stable but also reversible solutions, in case something needs to be modified later.
PeoDaniel6 Mar 2024 08:52For fastening on pitched roofs, the following fixing methods are recommended:
- Heavy-duty or mounting brackets made of galvanized steel
- Longitudinal screwing on the back panels with frame components or wood
- Use of adjustable furniture feet on uneven floors
- For reversible installation, screws with a Torx drive or countersunk heads that can be easily removed later
It is important to have a well-thought-out installation concept that allows cabinets to be safely loaded while also enabling individual modules to be detached if necessary.
I used simple brackets measuring 50 x 50 mm (2 x 2 inches), which are screwed under the carcasses and then fixed to the wall. This leaves no major damage to the furniture when removed.
