ᐅ Is it possible to replace or repair Brimnes drawers from IKEA?
Created on: 29 Sep 2021 08:47
Haoson
Haoson
29 Sep 2021 08:47
I have a question regarding the Brimnes drawers from IKEA. Specifically, I would like to know if it is possible to replace or repair individual drawers in this piece of furniture. I am particularly interested in whether damaged or defective drawer fronts, runners, or even entire drawer units can be purchased separately without needing to replace the entire unit. If repair kits or spare parts are available, I would also appreciate any advice on the best way to install them or any special tips to keep in mind.
Thank you in advance for your support and shared experiences!
KAUDRA62
29 Sep 2021 09:12
Hey Haoson!
Great question – the Brimnes series is really popular, and it’s unfortunate when only one drawer stops working. IKEA does offer spare parts, but availability varies a lot depending on the country. Sometimes you can get fronts, runners, or knobs individually, but usually only through customer service or directly in the store. If the runner is bent or broken, I recommend carefully getting a replacement runner, which can be easily slid in. You can also try repairing it yourself; if a wooden part is chipped, wood glue or small screws can fix quite a bit – it’s not complicated. 😊 It’s best to ask IKEA directly and have the exact product number ready, that usually works well.
Jatau
29 Sep 2021 11:26
Drawer fronts in Brimnes are replaced using a clip-on system. Spare parts are available from IKEA upon request. Rails can also be purchased separately. Installation is straightforward.
LANICOLE
29 Sep 2021 15:47
As a supplement: If you want to repair or replace a Brimnes drawer, please follow these steps:
- First, note the product number, often found on the back or underside of the drawer.
- Contact IKEA customer service or the information desk directly to request spare parts.
- Replacement fronts or runners can be ordered separately, depending on availability.
- To remove the drawer from a Brimnes unit: pull the drawer out fully, then lift the front and pull it out.
- If the runner is damaged, replacement is usually quick as the runners are simply screwed in place.
Important: Patience may be necessary, as spare parts are not always immediately available and delivery times can vary. If replacing aluminum runners, carefully compare the measurements to ensure stable guidance. For wood repairs, using appropriate wood filler and high-quality screws is worthwhile for better durability.
Haoson
30 Sep 2021 10:03
KAUDRA62 schrieb:
IKEA does offer replacement parts, but availability varies widely depending on stock and the country.
This is an important point for me. I live in a smaller town and wonder if it is generally possible to order replacement parts online from IKEA in case the local store’s stock is insufficient.
Also, I would be interested to hear if anyone has experience with how straightforward it is to find replacement parts for Brimnes – does it usually go smoothly, or is it more of a lengthy process?
At the same time: Does anyone have tips on how to properly remove and reinstall drawer fronts without damaging the fittings or the material? Thank you!
Dopoki
30 Sep 2021 13:51
Haoson schrieb:
I live in a smaller town and wonder if it is generally possible to order spare parts from IKEA online, in case the local store does not have enough stock.
IKEA basically offers an online customer service through which spare parts can be ordered. However, availability depends heavily on current stock levels and varies by product.
The drawer fronts of the Brimnes series are usually attached with special snap-in mechanisms that allow easy removal when you fully pull out the drawer and carefully release the locks at the front. It is important not to use force and to precisely locate the attachment points. Be cautious with the plastic clips, as they can break if handled too roughly.
