ᐅ Calculated Settlement Behavior of a Single-Family House – Tolerance Range
Created on: 8 Jul 2019 17:12
aequitasHello everyone,
Due to challenging ground conditions (backfilling of a former pond with construction debris from the 1960s) and the expected settlement associated with this, we are currently deciding between using micropiles (approximately €23,000) or soil replacement (cost depends on depth and soil classification for disposal) for a new build.
Different settlement behaviors are expected (calculated) for each option:
1. Soil replacement with a 0.5 m (20 inches) gravel cushion: approximately 3.1 - 5.1 cm (1.2 - 2.0 inches)
2. Soil replacement with a 1.0 m (40 inches) gravel cushion: approximately 2.8 - 4.5 cm (1.1 - 1.8 inches)
3. Soil replacement with a 1.5 m (59 inches) gravel cushion: approximately 2.3 - 3.6 cm (0.9 - 1.4 inches)
4. Micropiles: approximately 1 cm (0.4 inches)
From experience, how much settlement is generally considered acceptable? We are planning a solid wood house with a 96 m² (1,033 ft²) footprint on a concrete slab.
If soil replacement would keep settlement within tolerable limits, we would need to refine costs through a thorough soil assessment.
I would appreciate any insights or shared experiences.
Stefan
Stefan
HilfeHilfe8 Jul 2019 18:12Option 4 seems to be the best choice as the costs are clear. How much do options 1-3 cost?
Option 1 would be nearly cost-neutral except for the gravel, as we need the same amount of excavation for Option 4 as well.
Option 2 would result in about 96 tons of excavated material after subtracting 0.5 m (20 inches) of excavation. With estimated disposal costs between 20-80€ per ton, the total would be roughly 1,920 - 7,680€.
Option 3 involves about 192 tons of excavated material, with disposal costs ranging from approximately 3,840 to 15,360€.
Gravel costs around 20€ per ton. With a density of 1.5 tons per cubic meter (60 pounds per cubic foot), this adds roughly 1,440€ for Option 2 (about 72 tons) and 2,880€ for Option 3 (about 144 tons).
If the calculation is correct, soil replacement would generally be the more economical choice—provided that the higher settlement is not an issue. What do you think?
HilfeHilfe9 Jul 2019 06:11I would now calculate everything in centimeters.
For example, Option 2; worst case 7,680 for 4.5 cm (1.8 inches) = to reach about 1 cm (0.4 inches) we would be at €34,560.
Then, for the earthworks, there are certainly estimated costs, as you have quite a wide range with Options 2 and 3.
Who guarantees that it won’t be 8 cm (3.1 inches)? In the end, you could have a house that settles unevenly everywhere.
