ᐅ Is it practical to use Kabel Deutschland and Telekom together?
Created on: 13 Mar 2013 19:04
Ahnungslos
Ahnungslos
13 Mar 2013 19:04
I will soon start building, and now the following question comes up regarding the utility connections.
We are planning to use a satellite dish for TV, and for internet and phone, we want to go with Kabel Deutschland.
Would you still have a Telekom line installed in the house as well? Or is that even required?
I actually don’t want to have anything to do with Telekom anymore, but I also don’t want to be dependent on just one provider. Would you bite the bullet and have a connection installed and pay for it, even if you might never use it?
perlenmann
14 Mar 2013 08:25
You will then depend on the network operator. The main provider only installs the cable, but ultimately you can order from other companies. It costs €384 (about $404). I would do it (I have it too). However, I don’t have a cable for it since I want satellite TV.
emer14 Mar 2013 09:45
I would also have both installed. As "Perlenmann" already mentioned, Telekom only installs the cable. And since the ground is dug up only once anyway.
Der Da14 Mar 2013 10:27
In any case, have it installed. What will you do if someday your boss says: “Hey, you’ll be working from home occasionally from now on, and I’ll pay for your home internet connection” (like my boss does currently)? And this internet connection has to be through Telekom due to contracts. Then you’re stuck with a problem and might have to dig everything up again.
Of course, your boss can hardly force you to do that, but I personally like to see working from home as an opportunity to avoid some of the daily commute traffic.
Or another scenario: you experience performance issues with Kabel Deutschland. What then? Or they terminate your contract because your child causes monthly traffic of 100 gigabytes (I have already been threatened by KabelBW for distributing my own Linux distribution and having massive traffic peaks over three months).
So I would invest the 400 € or have a remote office set up at your house for free, just in case.
Wastl
14 Mar 2013 10:59
Have you already inquired with Kabel Deutschland? In our new development area, no cable was installed, and we were not even offered an option; the installation was simply declined.
Ahnungslos
14 Mar 2013 12:10
Thank you first of all for the responses.
I basically see it the same way. This is probably not the place to cut costs.
@Wastl: No, I haven’t called yet; I only did an availability check online. According to that, it should work, but I heard yesterday that our future neighbors had some issues with their telecom connection. Apparently, the telecom provider didn’t connect them. But I’ll ask about that.
