ᐅ Burglary Protection – Upgrading Windows from Resistance Class WK2 to WK3 – Alarm System?
Created on: 13 Jan 2017 09:52
Mycraft
Hello dear forum community,
Due to recent events, I would like to ask how new and experienced homeowners think about burglary protection and what measures they have installed or are planning to install. Also, whether anyone has had good or bad experiences with certain products.
Now, regarding the current situation: last week, there was a break-in at our immediate neighbors’ houses and then at two houses behind us.
In one case, there was an attempt to lift the front door, but the triple locking mechanism held... then the intruder tried the terrace door (security level WK1), which gave way.
At the other house, an attempt was made at a small window behind the house (WK3), which also failed, and then at the terrace door (WK3). Here, the roller shutter was torn off and the triple glazing was smashed.
In summary, jewelry, electronics, and all small valuable items were stolen, as well as coats and similar items. Larger items were left behind, but everything was thoroughly searched and violently broken into.
The day before yesterday, another break-in occurred a few streets away… all around dusk, about 5-6 pm.
We have WK2 windows, and I will now upgrade them to WK3 (already ordered). But what about the glass? I won’t be able to replace all panes with laminated glass, it’s just not feasible. Has anyone had experience with films that are applied from the inside (300 mil)?
Besides that, we have video surveillance all around... We are now installing ten 20W LED floodlights around the house, which turn on when motion is detected and stay on for a while (directed away from the house).
Additionally, a siren will be installed on the roof, connected to the KNX alarm system, which will activate in case of glass breakage or unauthorized window opening. (I still have to buy the glass break detectors).
For the large windows, I have also ordered rod locks because the weak point is in the middle where there is no central bar.
Mycraft7 Apr 2017 14:35
If a house has a more or less smart electrical system and almost everything is "communicating" with each other, then you can achieve quite a lot with it...
Another application we use is:
As long as the patio door is open, the roller shutter remains up, even if the others go down due to sun, dusk, or time...
nms_hs
7 Apr 2017 17:12
Do you always leave your patio door open when you are on the terrace? Or do you use additional sensors to detect when the garden is being used?
sirhc7 Apr 2017 18:45
Unfortunately, our electrical system is not smart. I had hoped for the terrace door feature as well, but it could not be implemented.
Unfortunately, the budget is limited, and KNX was the first to be cut. Second and last to go were the great digital room thermostats – only the living room has one. However, each window does get an astro shutter switch, at least.
Mycraft8 Apr 2017 02:12
nms_hs schrieb:
Do you always leave your patio door open when you’re on the terrace? Or do you use additional sensors to detect garden use?
No, leaving the door open would be pointless... of course, there are additional sensors.
sirhc schrieb:
Secondly, and lastly, the great digital room thermostats – we only have one of those in the living room. But every window gets an astro roller shutter switch, at least.
It may be that thermostats are necessary for you; you can always replace them and install the advanced ones instead of the basic models.
Because of the bus system, I only need one weather station, which can then provide all the roller shutters with the required information, including the astro function.
nms_hs
8 Apr 2017 16:33
And how did you set up the terrace usage sensor? I’m having trouble picturing it. Motion detector? Outdoor occupancy sensor? Separate Wi-Fi outside?
Mycraft8 Apr 2017 17:50
IP cameras detect movement in the garden/terrace and the light is also involved, meaning the terrace light turns on -> shutter locked. In addition, there is presence detection inside, occupancy of the residents, season, and so on.
So it is a combination or interaction of various sensors to prevent locking out residents/guests.
