ᐅ Please review the design for a bungalow with a converted attic, approximately 135 m² (non-professional draft).
Created on: 26 Mar 2018 21:28
jawknee
I often read that you don’t need to think too much about the floor plan before visiting a construction company or architect, since it usually changes anyway in the end. But I just can’t help it and want to think through as much as possible from the start 😉 I also don’t want to have to completely redo everything after the first consultation if something turns out to be impossible.
Plot size: approx. 750m² (8500 sq ft), will be developed soon, reserved
Slope: slightly sloping to the south, but almost flat
Site coverage ratio (floor space index): 0.4
Floor area ratio (FAR): 0.8
Building envelope, building line and boundary: approx. 17 x 16m (56 x 52 ft)
Surrounding buildings: see image
Number of floors: ground floor + attic
Roof style: hip roof, up to 35 degrees, 80cm (31 inches) knee wall
Architectural style: bungalow
Orientation: see image
Maximum heights / limits: ridge height 6.5m (21 ft)
Additional requirements: garage with gable roof
Owner’s Requirements
Style, roof type, building type: as specified by development plan
Basement, floors: no basement, ground floor + converted attic
Number of occupants, age: 1 (33 years old), but must be suitable for up to 3 people
Space requirements ground floor / upper floor: ground floor approx. 80m² (860 sq ft) / attic approx. 50m² (540 sq ft) (not necessarily divided exactly like this)
Office: family use or home office?: gaming room + occasional home office
Guest bedrooms per year: planning for up to 2 guests per quarter
Open or closed floor plan: closed
Conservative or modern construction: rather conservative, coziness is the priority
Open kitchen, kitchen island: no, closed kitchen or kitchen island
Number of dining seats: 5-6
Fireplace: definitely
Music / stereo wall: regular entertainment unit with TV
Garage, carport: single garage (possibly with storage room) + open single parking space (according to development plan with gable roof, but in the neighborhood there are flat roofs as well, the latter is preferred and to be clarified)
Vegetable garden, greenhouse: nothing special, just a regular vegetable patch
Other wishes: controlled mechanical ventilation system likely (hardly imaginable to go without these days)
Designed by: DIY (Excel)
What do you particularly like and why?: Here’s everything important to me:
- I find the bedrooms and bathrooms cozier in the attic, also because you don’t have to feel like someone might pass by the window at any time, purely a feeling issue.
- Bedroom as far from utility room as possible due to noise; also not fully southwest-facing to avoid heat in summer.
- Bedroom fairly spacious (even though many just see the bedroom as a sleeping cabin). I’m currently quite bothered in my 12m² (130 sq ft) bedroom by bumping into things, facing the wardrobe wall, having little space to dress, and it just being a dark box for sleeping. Also, I think it’s a good idea to have a spare room in case I ever need some space away from (yet to be found) partner or if the lady wants to quietly lay out her yoga mat 😀
- Bathroom large enough with open shower without glass screen (I don’t like those).
- Covered terrace in front of dining/living area, as I am not a fan of direct harsh sunlight (not a sun worshiper), and the terrace can be used even in less favorable weather. Still unsure if the light conditions will be sufficient.
- No bedroom doors / walkways in dirty areas.
- Staircase not located in dirty area and as central as possible.
- Dormers for more space, better aesthetics, and general benefits of dormers.
- Combined living/dining room; kitchen separate from that.
- At least 1 additional room for office/hobby/child; ideally 2.
- Roof slopes used as storage space.
What don’t you like? Why?: Since it’s my own design, not much so far:
- Entrance area maybe still a bit narrow and perhaps could be better separated from the staircase(?)
- I’m not sure if the bedroom can be built structurally without additional supports (affects spatial feeling).
Cost estimate according to architect/designer: not available yet
Personal price limit for house, including equipment: 320k
Preferred heating technology: heat pump or gas (still undecided)
If you have to give up certain details / features
- Could give up: canopy above entrance, storage closet; everything else I have already removed for cost reasons ^^
- Cannot give up: fireplace, bathroom with bathtub, covered terrace
Why is the design as it is now? E.g.
I am initially building the house for myself, I’m single, but want to plan the house to still be comfortable for up to three people if needed.
Only a bungalow is allowed on this plot, and I experimented with single-story floor plans but couldn’t really find one that fits well into the building envelope. I’m also a fan of attic floors (as long as they don’t turn into saunas).
Originally, I thought about 120m² (1290 sq ft) and believed that’d be enough, but in the end, it’s about 135m² (1450 sq ft) to really feel comfortable.
I struggled a lot with fitting the rooms properly under the many roof slopes, moved rooms around a lot, but either a room then had too much roof slope or it didn’t fit well with the ground floor (e.g., utility room under the bedroom).
Since it’s my own design, I want to know if there are any glaring errors that are objectively just nonsense. Personal taste should be left out.
PS: I hope detailed dimensions are not necessary at this stage; otherwise, I’ll try to add them later.
jawknee schrieb:
I think we might be talking past each other 😉 There is no option to choose within a specific subarea. Why? – I understood
jawknee schrieb:
that, when looking at the entire area, you can of course choose between the three options, but the plot must be located within the corresponding subarea. So far, it was like this: in 1.1 you can choose between "old" and "1.1 new," and in 1.2 between "old" and "1.2 new"; and I assumed that 1 is divided into 1.1 and 1.2. Or are 1.1 and 1.2 just separate offshoots, and 1 is not the overall area containing 1.1 and 1.2, but rather an adjacent area that remained unchanged?
Is 1.1 and 1.2 instead just subdivisions, and 1 is not the parent zone of 1.1 and 1.2, but a separate, unchanged area next to them?That’s what I meant.
In the past, there was only 1, and now next to 1 there are also 1.1 and 1.2.
I understand that the use of “also” could be interpreted differently, but I’m quite sure that each subarea only allows the specific variant assigned to it, because the real estate agent explained this to me that way and marked it accordingly on the plan before I even saw the development plan myself:
WA1 = Franconian style (gable roof)
WA1.1 = Bungalow (hip roof)
WA1.2 = Mediterranean style / city villa (pyramid roof)
Further down, it also states that “quarters” are deliberately formed (this wasn’t visible on the last screenshot), within which mixing of styles is not allowed.
jawknee schrieb:
but I am pretty sure that each sub-area only allows the respective single option, If there are three areas (1, 1.1, and 1.2), then probably yes. I assumed that area 1 is completely divided into 1.1 and 1.2, and that you are allowed to choose the construction method that was already possible in 1.1 and 1.2, just not the one from the other sub-area.
jawknee schrieb:
I am actually quite sure about thatIf you are only "actually quite sure" here, I would definitely recommend seeking a 100% confirmation by contacting the relevant building authority.
That could open up many more options for you.
As confident as I was, you have now made me a bit unsure 😉
I checked again with the local authority, but it turned out just as I thought. Only the bungalow option is allowed on my plot.
I also found out that the garage must be built with a hip roof, which was actually different from what I understood from the development plan.
jawknee schrieb:
that the garage must also be built with a hip roof actually came across differently to me from the development plan. In the illustration, this point is about the symbolic placement of the house. The assumed gable roofs probably only indicate the ridge directions.
