ᐅ Building without antenna and satellite or coaxial cables without conduit?
Created on: 6 Jun 2020 12:18
kati1337
we received the additional electrical work quote today (ouch), and the contractor is basically getting very little because we decided to remove both the antenna and satellite connections.
Now I’m wondering if we are really that far off base or if I missed something. The antenna is that old-fashioned cable through which you could only receive channels like ARD, ZDF, and some regional channels back in the ’90s, right? Are there more channels available via antenna now? Is it even necessary? Does everyone just “have one”?
We currently have a satellite dish on the roof, but I believe the last time we actually used it was... I don’t know, 8 years ago?
So we were thinking about not installing a satellite connection at all. We simply don’t watch TV via satellite. I hate commercials, and when we do watch anything, it’s through streaming services. Plus, in our free time, we mostly do other things than watch TV anyway.
Are there any compelling reasons why we should still have satellite or antenna connections installed that I might be overlooking?
Topic 2: The electrical quote states that the CAT cables will be installed without conduits. I would prefer them to be installed with conduits so they can be replaced if needed in the future. Would you go for that? Or is it unnecessary?
hanse987
9 Jun 2020 09:38
M4rvin schrieb:
You don’t need a box for the access point! They should just let a CAT cable hang down from the ceiling!
How do you connect the access point to the network cable then?
rick20189 Jun 2020 10:24
Keystone module. Then install the access point above it.
hanse987
9 Jun 2020 20:42
With a drywall ceiling, you can push the keystone module back into the ceiling cavity, but with a concrete ceiling, it becomes difficult.
ivenh0
9 Jun 2020 21:22
hanse987 schrieb:
With a drywall ceiling, you can push the keystone module back into the ceiling cavity, but with a concrete ceiling, that’s difficult.
For this reason, I directly pulled a patch cable through. It worked perfectly. The keystone probably wouldn’t have been able to be pulled back into the conduit.
rick20189 Jun 2020 21:56
30mm (1.2 inches) hole and it fits
Tarnari9 Jun 2020 22:20
Think of it as hanging, and it fits xD
