Hello everyone
We keep having disagreements about this topic.
How did you build your house? With or without a basement?
On one hand, I think: More space just means more room to store more stuff.
I have also considered compensating for the space by having a large double garage.
An attic would "also" be available then.
Hmm.....
I would appreciate your experiences.
I’ve also heard that not having a basement can be problematic because of moisture?
And cold from below?
Hmm.....
Bautraum2015 schrieb:
All houses from the 1970s are drafty. ....What kind of wisdom is that?
Link: Tante Gurgel + energy saving in the household + energy + building + modernization .....
I did not differentiate between air leaks and other types of leaks. Keyword: energy-efficient renovation
Bauexperte2 Feb 2015 13:17Hello,
Regards, Bauexperte
Wastl schrieb:Everyone reads what they want to understand.
So according to the unanimous opinion here, it's a "waste of money."
Wastl schrieb:Sorry, I don’t understand... Ground floor + first floor + converted attic and then 140 sqm (1,500 sq ft) of floor area?
The development plan only allows building about 70 sqm (750 sq ft) of floor area – but with an upper floor and a converted attic. Altogether, this results in roughly 140 sqm (1,500 sq ft) of living space.
Wastl schrieb:Counter question: what do people do who currently cannot afford a basement? Isn’t it rather true that good space planning should be the “alpha and omega” of every project?
Now I’m supposed to explain where to do laundry, install heating, store groceries, keep winter/summer clothes, etc. This would only have been possible with significant compromises to the living quality.
Wastl schrieb:Agreed.
The questions about having or not having a basement are so individual,
Wastl schrieb:Agree again.
that no general answer is possible –
Wastl schrieb:This statement is almost true—at least based on results from my part-time work.
even if in NW maybe everyone builds without and in BY everyone builds with one,...
Regards, Bauexperte
Bauexperte2 Feb 2015 13:25Hello,
Furthermore, your statement "in the 70s all houses were drafty" is not entirely accurate, as it implies that a certain level of air exchange was harmful (in terms of building construction). This is definitely not the case! For example, when I look at today’s energy-saving regulations, I actually preferred the way windows were installed back then; there were fewer moisture-related damages. Today, to achieve the same result, a ventilation system must be installed. So the question arises: which was more reasonable from a construction point of view.
Regards, Bauexperte
Bautraum2015 schrieb:This link is a disguised advertisement; so I wouldn’t read too much into it in your place.
I didn’t differentiate between air leaks and other types of leaks. Keyword: energy renovation
Regards, Bauexperte
You are absolutely right. The link was just the first one that appeared when searching for a house from the 1970s. Personally, I’m not in favor of a completely airtight building envelope, by the way. But most energy retrofit projects are carried out on houses from that era.
Bauexperte2 Feb 2015 13:30Hello,
Yes, that’s correct. It mainly refers to insulation, windows, and the roof. However, today’s renovators pay more attention to the combination of windows and insulation than they did five years ago; at least it’s a good start.
Best regards, Bauexperte
But most energy renovations are indeed done on houses from that period
