ᐅ Building Stair Railings with Aerated Concrete Blocks – Is It Stable?
Created on: 28 Jun 2018 15:04
Snowy36
I have a question... Our construction manager wants to build a railing on our 1.07m (3.5 ft) wide concrete staircase using 7cm (2.75 inches) Ytong blocks and then plaster it...
From the beginning, we wanted a masonry railing, but now the stairwell opening is quite large, so a full wall from top to bottom across the two floors is no longer possible...
But will something like this hold? Has anyone done this before?
IsabellaMS8 Sep 2018 07:00We want to do something like this. Using 15cm (6 inches) Ytong blocks, then applying a bonding layer and plastering.
Knallkörper8 Sep 2018 09:31I still have my concerns. The joint is brittle (meaning "not tough") and especially at the base point, it can break relatively easily if a sudden impact is applied to the railing.
IsabellaMS8 Sep 2018 09:44@Snowy36 thank you!!!
Knallkörper schrieb:
I would still have my doubts. The joint is rather brittle (in the sense of "not tough"), and especially at the base, it can break relatively easily if there is a sudden impact load on the railing.That is fundamentally correct. It depends on whether the adhesive was applied properly and on the stair construction. With a landing staircase, there is an interlocking structure that better absorbs lateral forces. For a straight staircase, I would be more critical.
A structural engineer would probably not approve such a construction. In practice, after plastering, I don’t see any problems as long as a 100kg (220 lbs) bowling ball doesn’t crash into it with full force.
