ᐅ Building plot located in a hollow, neighboring properties are situated at a higher elevation
Created on: 5 Aug 2021 00:10
Fjeroch
I’m looking for some opinions about a plot of land. We have received approval from the local authority and now need to make a final decision.
The plot is lower than the neighboring houses. At the back, it is almost 2 meters (6.5 feet) lower, and on the left side, one neighbor has a basement and has built a tall house.
The neighbors have not raised their plots, so for example, we would need to use retaining walls (such as L-shaped concrete blocks) to support the soil.
What do you think?
Construction site: multi-story house under shell with scaffolding, crane on the left, garbage bags in the foreground.
rick20185 Aug 2021 06:46
I would definitely raise the plot to street level. Possibly higher at the back as well. Construction is happening all around, so you should be able to find fill material for free. Then cover the top layer with topsoil. Otherwise, you will constantly have drainage and landslide issues, even though that would be the responsibility of the party causing it.
Fjeroch
5 Aug 2021 06:48
rick2018 schrieb:
I would definitely raise the plot to street level. Maybe even higher at the back.
There’s construction everywhere, so you should be able to find material to fill for free.
Top layer with topsoil.
Otherwise, you will always have to deal with drainage and landslide issues, even though that would be the responsibility of whoever causes it.
Filling at the back sounds good, but would you then build a basement?
We would like to plan without a basement.
rick20185 Aug 2021 07:27
You have to build directly on the plot.
A basement is probably advisable here. Under the house, you need better soil compaction than in the garden...
Get a good architect and have them make some proposals.
hanghaus2000
5 Aug 2021 10:33
Is the dashed line the building boundary?
Is it allowed to construct the garage or carport outside the building boundary?
Fjeroch
5 Aug 2021 12:11
Is it allowed to build the garage or carport outside the building boundary?
Yes, exactly, the garage may be built outside the building boundary.
driver55
5 Aug 2021 12:30
Fjeroch schrieb:
We have received approval from the municipality and now need to make a final decision.
So you did apply after all!? Why wouldn’t you check the developability at the same time as the “reservation”?
You can get something out of (almost) any plot and develop it optimally, but the effort and costs can vary greatly.
