ᐅ Building Physics: Different Types of Masonry Units?
Created on: 2 Mar 2020 13:12
Seven1984
Seven1984
2 Mar 2020 13:12
Is there any reason not to build non-load-bearing interior walls with BIMS construction boards in a room where the walls are made of T7 Poroton blocks?
Thank you!
11ant2 Mar 2020 13:25
From my point of view, nothing – but why use lightweight concrete blockboard instead of gypsum board here?
Seven1984
2 Mar 2020 14:43
Hi, well, I actually wanted to have the interior walls solid as well. They come in 11.5cm (4.5 inches) then. Thanks!
11ant2 Mar 2020 23:42
Seven1984 schrieb:
Hi, well, I actually wanted the interior walls to be solid as well.
Both are solid (???)
Seven1984 schrieb:
then there is 11.5 cm
11.5 cm (4.5 inches) of which type of brick exactly?
goalkeeper
3 Mar 2020 02:09
Gypsum wallboard panels are even available in 10mm (0.4 inches) thickness.
