ᐅ Building Physics Design of the Garage Floor/Ceiling Assembly
Created on: 4 May 2026 15:33
O
Olele153Hello everyone,
We are currently in the final phase of our house construction, but we still have a major project ahead of us: the garage.
The garage is built as a solid structure, directly connected to the utility room (separated by an FH30 fire-rated door) and features a pitched roof with exposed wooden beams. All the house connections (water, electricity, internet, meter cabinet, photovoltaic inverter, and battery) are installed in the garage, following consultations with the respective suppliers and contractors, which is why it needs to be frost-proof.
For aesthetic reasons, my partner would like to keep the wooden beams of the ceiling visible and cover them with OSB panels on top to achieve a full "wood look" and because we have some leftover panels. (The visual result is subjective, but happy wife...)
The basic idea, from my father and me, was to screw the OSB panels directly onto the beams and then lay insulation on top to protect against cold coming through the roof. Ideally, this insulation would be walkable so that the space could possibly be used as a small storage area (emphasis on possibly, small scale, and could... I do not plan to store hundreds of kilograms of materials up there). We were thinking of using XPS insulation in an appropriate thickness.
However, our knowledge of building physics is very limited. Do we need a vapor barrier? If so, where and how should it be installed? Can glued OSB panels serve as a vapor barrier? Is the insulation effect of XPS sufficient to protect the garage from cold coming through the roof? Is there anything else we should consider against this construction method?
If anyone has some helpful tips or maybe has a similar setup and can explain how such a construction can be done well, I would be very grateful.
Thank you!
Thank you!
