ᐅ Building Permit Obtained – How to Request Quotes from Construction Companies?
Created on: 31 Oct 2015 14:45
2
2miam2
we already have the building permit / planning permission. Now we are trying to get quotes from construction companies. (We know we could have left this to the architect, but we wanted to handle it ourselves!)
Our question is: How does this usually work? The first steps are already taken. We have called construction companies and asked for a quote. According to them, we should provide all available documents (floor plans, structural engineering). Do contractors need any additional documents? We also want to contract the other trades in the same way. How should we word this in the cover letter? Should the quote cover only the masonry work? SO MANY QUESTIONS
merlin83
31 Oct 2015 17:01
Just the architect’s contacts with the contractors saved us tens of thousands during the shell construction phase.
wrobel1 Nov 2015 10:10
Hello
Generally, I agree with the previous writers.
If you have no experience at all, then go with an architect or a general contractor for a "turnkey" solution.
BUT, it is definitely not true that all companies sending an offer to a private builder are unreliable.
Olli
merlin83
1 Nov 2015 10:46
wrobel schrieb:
Hello
I generally agree with the previous posters.
If you have absolutely no idea, then going with an architect or a general contractor for a “turnkey” solution makes sense.
BUT, it’s definitely not true that all companies sending private home builders an offer are unreliable.
Olli
No, not all... but in our case at least 15% more expensive.
alexm86
1 Nov 2015 11:07
@merlin83 How did you get behind it?
merlin83
1 Nov 2015 11:52
The main contractor I introduced was 15% more expensive; the retaining walls I provided were about 40% to 70% more expensive. The structural engineer I recommended was also 10% more expensive.
Sebastian79
1 Nov 2015 16:13
This certainly cannot be generally assessed – and so far, you haven’t completed any work, have you?
I would rather ask why your architect is offering such inexpensive companies and you don’t get a deal with them – they usually have no connection to each other.
I only chose one company recommended by the architect (window manufacturer) – not deliberately, but it just happened that way.
