ᐅ Building with American light-frame construction. Who has experience?
Created on: 13 Jun 2009 15:52
eule1904
eule1904
13 Jun 2009 15:52
Hello, I am currently considering building my future home myself using a timber frame construction method.
This construction method is commonly used in the USA.
Now my question is whether anyone has experience with self-building this type of structure.
I would be very happy to receive a reply from you.
Danton
14 Jun 2009 14:14
Hello eule1904,
First of all, in Germany, residential buildings using wood frame construction are built both by carpentry companies and many prefabricated house manufacturers. These generally maintain a significantly higher quality standard than their counterparts in the USA.
In wood frame construction, it is crucial to ensure flawless and professional detail planning as well as execution, because otherwise, after several years of use, the house can essentially become hazardous waste due to mold infestation.
I would only recommend self-building if the planning is done by an experienced architect or structural engineer, and the person responsible for the construction is very knowledgeable about timber construction.
JOERG24
16 Jun 2009 13:20
American construction methods often differ in that much thinner cross-sections are used. Here, 160mm (6.3 inches) is typically the smallest structural dimension for the main stud framework. However, there are also houses with 200mm (7.9 inches) and 240mm (9.4 inches) studs. That contributes significantly to stability.
Also, houses there are usually nailed together (including to the foundation), whereas screw connections are common here.
There are numerous technical books that cover the construction method. However, I would argue that you should already have some woodworking skills—for example, being able to make joinery cuts.
Initially, you would need a preliminary plan and a structural engineering analysis. Simply buying wood and nailing it together is not enough.
For self-build projects, I find the masonry option more practical and probably more cost-effective.
There are also suppliers offering timber frame house kits. That might be the best solution if you want a wooden house.
