ᐅ Building IKEA Metod Kitchen Islands with a Practical Bar Counter Solution Yourself
Created on: 26 Jan 2021 10:13
Dikledian
Dikledian
26 Jan 2021 10:13
Hello everyone, I am currently planning my kitchen using Ikea Metod cabinets and want to build a kitchen island with an integrated bar counter myself. The kitchen island should not only provide storage but also a bar-like area for dining or casual use — ideally designed so that the counter surface is easily accessible and separated from the main workspace of the island. My questions are: How have you integrated practical bar counters with your Metod kitchen islands? What materials do you use for the countertop to ensure it stays sturdy and easy to maintain? Are there any special assembly or installation tips to keep in mind, especially when working with Metod cabinets? I’m looking forward to your experiences and advice, thanks in advance!
Jamalli
26 Jan 2021 11:47
Dikledian schrieb:
How did you integrate your Metod kitchen islands with those practical countertops?
Interesting question, but your explanation is missing details on how exactly the countertop should be incorporated into the design: Should it be at the same height as the main work surface or raised like a bar counter?
I ask because the structural support and stability of the countertop extension greatly depend on the design. A simple approach is combining Metod carcasses with a slightly thicker countertop and recessed support profiles, but this needs careful planning, otherwise the countertop will wobble when leaned on.
Also: What is your intended use? Quick breakfasts? Seating with bar stools as well? Material requirements vary significantly depending on this.
Could you please clarify these points so we can offer more detailed advice?
lorena
27 Jan 2021 14:22
For detailed planning of a kitchen island with Metod cabinets and a practical bar counter solution, I recommend the following approach:
- First, determine the basic dimensions: Metod cabinets have standard sizes, usually 60x37x80 cm (WxDxH), so the counter height should be at least 110-115 cm (43-45 inches) if it is to be used as a standing bar.
- For the countertop, a durable surface like solid wood (beech, oak) is suitable, treated with oil or lacquer to make it easy to maintain and resistant. Alternatively, laminated countertops are possible, which require little maintenance.
- It is important to securely fasten the countertop. I recommend a substructure of sturdy brackets (metal or wood) at the side of the island to support the countertop and prevent tipping. Metod cabinets themselves are not designed to support the weight of the counter.
- Also, pay attention to a proper connection between the counter and the island to avoid narrow gaps or unevenness.
- If electrical installations are desired (lighting or power outlets under the counter), these should be planned early.
Is there already an idea of how deep or large the island should be?
barEsperan
27 Jan 2021 16:59
Dikledian schrieb:
Which materials do you use for the countertop surface to keep it sturdy and easy to maintain?
Bamboo or laminate countertops are affordable and durable. For extra stability, secure wood panels with angle brackets. Laminate is unbeatable when it comes to ease of maintenance.
KLONA
28 Jan 2021 08:41
The following technical considerations apply to countertop solutions for Ikea Metod kitchen islands:
- Standard Metod cabinets are not designed to support point loads from overhanging countertops. Therefore, the countertop should be reinforced with its own support posts or brackets.
- Height differences between the countertop and the bar surface require precise leveling using adjustable feet on the cabinets or intermediate elements to maintain exact alignment.
- For installation, it is recommended to secure the countertop at least at three points: directly on metal brackets, support feet, and, if applicable, on the wall.
- Cut countertops must be carefully sanded and sealed to prevent moisture damage.
- Ensure the countertop height remains ergonomically appropriate: 110–115 cm (43–45 inches) is ideal for bar stools. For seating at working height, the recommended height is about 90 cm (35 inches).
- Fastenings should use appropriate screws (e.g., countersunk screws) and anchors to guarantee load capacity.
If the countertop is particularly heavy, additional metal supports may be advisable.
Can anyone share specific solutions with Metod and countertops under daily use?
