saralina871 May 2020 18:46Unfortunately, I can't provide any input on the driveway, but the distance to the property boundary seems a bit narrow to me... Are you allowed to build that close to the boundary where you are?
K.Schulte schrieb:
Would it even be possible to build a house there? Maybe.
Is there a development plan (building permit / planning permission)?
Is the sketch roughly to scale?
If both answers are no, please provide a generous section of the property map (tim-online).
Otherwise, please show the development plan and add measurements to the sketch.
K.Schulte schrieb:
Would it need a separate driveway for emergency vehicle access for the fire department? Please refer to §5 of the NRW building regulations. The access requirements depend on many factors. In my opinion, you would most likely have to give up the existing garage.
K.Schulte1 May 2020 19:01saralina87 schrieb:
Unfortunately, I can’t contribute anything about the driveway, but the distance to the property boundary looks a bit tight to me... Is it allowed to build so close to the boundary where you are?K
K.Schulte1 May 2020 19:03As far as I know, a 3-meter (10 feet) distance from the neighboring property must be maintained in NRW...
Escroda schrieb:
Maybe.
Is there a development plan / zoning plan?
If the answer to both is "no," please provide a generous section of the cadastral map (tim-online).
Have a look at §5 of the NRW Building Regulations. The condition of the access depends on many factors. In my opinion, you will most likely have to sacrifice the existing garage.
K.Schulte1 May 2020 19:04I should check if I can find a zoning plan in our documents..
K.Schulte schrieb:
K.Schulte1 May 2020 19:06K.Schulte schrieb:
As far as I know, in North Rhine-Westphalia a 3-meter (10 feet) distance from the neighboring property must be maintained... Similar topics
