ᐅ Wall blocks for garage
Created on: 5 Dec 2015 15:13
Holzwurm2002
Holzwurm2002
5 Dec 2015 15:13
Hi everyone,
Which type of masonry block would you recommend for a standalone double garage?
Thermal insulation value is not really a priority, more the cost...
Aerated concrete blocks, clay blocks with pores, or rather lightweight concrete blocks?
Aerated concrete seems to be the easiest to work with, right?
Wall thickness would be 240mm (9.5 inches).
I appreciate any tips.
lastdrop5 Dec 2015 16:17
Suitable answer to this question: It depends.
Holzwurm2002
6 Dec 2015 11:20
What really matters?
Peanuts74
9 Dec 2015 13:33
If insulation value is not a priority, sand-lime brick is a good choice, as you can also hang something heavy on the interior walls without special anchors. Additionally, sand-lime brick is affordable and it doesn’t matter if it isn’t plastered immediately (weather-resistant).
SirSydom
10 Dec 2015 10:36
The most cost-effective option is usually concrete hollow blocks – cheaper than sand-lime bricks.
I just checked my price lists.
Sand-lime bricks: 30€/m²
Concrete hollow blocks: 10€/m²
Peanuts74
10 Dec 2015 12:48
30 euros is quite expensive, even at Bauhaus the 17.5cm (7 inches) version costs about 25 euros per m² (per square meter), and at the wholesaler it is probably under 20 euros.
