ᐅ Flush Doors – Left-Hand or Right-Hand Hinged?
Created on: 10 Aug 2017 21:19
EA-Tec
I want to order doors tomorrow from the local specialist dealer. Before that: of course, I will discuss this topic with the dealer as well, but I am currently a bit confused and would like to understand on my own what door handing means for flush-fitting doors before I go to the dealer tomorrow.
Attached is a section of the floor plan showing the doors including the opening directions.
The opening direction will be changed for two doors. For the guest bathroom, the door should open outward, towards the main bathroom. The same applies to the storage room, meaning it should open not towards the kitchen, but towards the bathroom.
Could you please tell me, for each door, what type of handing it is?
I want to order as follows:
- Office 834x2097mm (33x82 inches), solid core including sound insulation
- Child’s room and bedroom 834x2097mm (33x82 inches), hollow core
- Bathroom 834x2097mm (33x82 inches), solid core
- Guest bathroom and storage room 709x2097mm (28x82 inches), hollow core
Does this look correct so far? Only the handing remains to be clarified.
The doors will be from the manufacturer Grauthoff, model Astra with flush edges and frame with Smart2 edge (probably better suited for flush-fitting doors).
Grundriss eines Hauses mit gekennzeichneten Zimmern Buro, Kind, Schlaf, Bad, Gast.
Traumfaenger
14 Aug 2017 22:56
bortel schrieb:
I also made my plinth flush, or rather, it is slightly recessed...
And how did you solve that? Did you create a shadow gap?
bortel
15 Aug 2017 06:08
What exactly do you mean—towards the door frame?
baufix42
15 Aug 2017 11:37
According to this, the office/child's room would be on the left side with the door hinged on the left.
Traumfaenger
15 Aug 2017 22:15
bortel schrieb:
I also made my base flush, or it is slightly recessed...
Traumfaenger schrieb:
How did you solve that? Did you create a shadow gap?
By base, I meant the area at the height of the skirting board and understood that you have the base flush (so no skirting board). That’s why I’m asking how you handled it—did you use a shadow gap instead of a skirting board?
bortel
16 Aug 2017 05:39
No extra baseboard… So between the door frame and the skirting tile, a small shadow gap forms. I installed the baseboard a bit recessed, but I would have preferred to have it almost flush so that the shadow gap would be even smaller.
EA-Tec16 Aug 2017 09:51
Sounds interesting! Do you have any pictures of it?
