ᐅ Bleeding Radiators: How Far Should You Open the Valve?
Created on: 2 Oct 2008 16:02
mr. dach-1
2 Oct 2008 16:02
Hello! Sorry for opening two threads in a row.
But I have a question about bleeding radiators. I know that you unscrew something on the radiator so that some water comes out. But how much should that be roughly? Just a little, or about a cup, or, or...?
And one more thing: Our radiator is making a humming noise. Is that normal, or is it related to bleeding?
Thanks
BauLine-1
3 Oct 2008 00:15
You need to bleed the radiator by opening the bleed valve (the screw at the top end or front of the radiator) until only water and no air comes out. Once this happens, you can close the valve again. Caution: Always keep the small bleed key in your fingers while doing this, or keep it close by, because after a brief “gurgling” sound, water will start flowing. Hold the cup or container at an angle to catch the water so it doesn’t spray into the room or against the wall due to the pressure.
The humming sound from the heating system is not caused by air. If air were present, you would hear bubbling or gurgling instead. If the noise bothers you or causes concern, have a professional inspect it.
Heini-1
13 Nov 2008 17:45
As long as air is still coming out, you need to keep bleeding the system. Only when all the air is gone is it properly done. However, bleeding it once is not enough; I would recommend doing it again after a few days because air often takes several days to fully escape from the pipes. As long as you hear gurgling sounds, you are not finished yet.
SonjaBiene-1
25 Mar 2016 19:59
You need to unscrew the bolt until the air has escaped.
