ᐅ Billy bookshelf wobbles: How can I fix the problem?
Created on: 7 Dec 2022 14:03
fokabla
fokabla
7 Dec 2022 14:03
A few weeks ago, I bought a Billy bookcase from IKEA, and recently I noticed that it wobbles slightly – basically, it moves a little back and forth whenever you touch or load it. The bookcase is standing on a relatively level laminate floor, and I have already checked that all the screws are tightened properly. Unfortunately, this did not lead to any noticeable improvement.
My question to you is: what could be the causes of this wobbling, and what steps can I take to secure the bookcase safely and steadily? I am especially interested in whether there are common weak points in Billy bookcases that should be specifically checked.
Thanks in advance for your advice!
Trate47
7 Dec 2022 14:57
Hey fokabla!
A wobbly BILLY shelf is definitely annoying – we’ve all been there! 😄 Often, it’s because the shelf isn’t standing perfectly straight or the wall mounting is missing or not secure enough. Check if all the furniture glides (pads) are properly installed; sometimes felt pads can help to better compensate for contact with the floor.
fokabla schrieb:
By the way, the shelf stands on a fairly level laminate floor
Even if the floor appears level, small uneven spots can cause wobbling. A simple wooden or plastic shim under the feet can work wonders! Also, see if you can still use the wall mounting – that’s usually the best way to prevent wobbling.
Good luck, and let us know how it goes! 😊
plopra
7 Dec 2022 15:42
Retighten screws, secure the shelf to the wall, level the floor, or place small shims underneath.
Usually, securing the shelf to the wall helps the most.
LOGEMIN
8 Dec 2022 09:15
Hello fokabla,
I would like to approach the problem systematically and list some key points that commonly cause BILLY shelves to wobble:
1. Check the screws: Even if you think they are tight, make sure to inspect all connections, especially those holding the back panel. BILLY shelves often gain their stability from the thin particleboard back panel, which is attached with small nails – if it is loose or missing, the unit will wobble easily.
2. Inspect and, if necessary, retrofit the back panel: A properly fitted back panel prevents side-to-side movement. Sometimes, additional small brackets should be installed.
3. Level uneven floors: As already mentioned, small wedges or felt pads under the feet help, especially on laminate or wooden floors.
4. Attach wall fixtures: The BILLY shelf normally comes with a bracket to secure it to the wall using anchors and screws. This anchoring is essential and prevents rocking under load.
If you have checked these points and the shelf still wobbles, there may be a material defect or deformation – but this is rare.
I hope this helps. If you like, I can also prepare a short checklist for you.
Best regards!
fokabla
8 Dec 2022 11:48
LOGEMIN schrieb:
the thin particleboard back panel, which is fixed with small nails
Thanks LOGEMIN, that was actually new to me. I hadn’t considered that this back panel is so critical for stability. I will now check it very carefully and, if needed, reinforce it or add small brackets.
Trate47 schrieb:
Good luck, and keep us updated on how it goes! 😊
I will! Regarding the wall mounting: I’m a bit unsure because my wall is made of thin drywall. Do you think the usual wall plugs can support the weight of a fully loaded BILLY shelf? Are there better options or special anchors for my type of wall?
Thanks to everyone in advance, your ideas are really helpful!
Dirkmin
9 Dec 2022 07:20
For wall mounting on drywall: standard anchors are often not sufficient here, as they do not provide the necessary holding strength.
I recommend using molly bolts or toggle anchors, which expand behind the drywall and can support significantly more weight.
It is important that, even when fixing to a thin wall, the pressure is distributed evenly. Use the screws supplied with the BILLY shelf along with appropriate anchors and, if possible, additional mounting points.
As an additional measure, you can also attach brackets to the back of the shelf, mounted perpendicular to the wall to increase stability.
Be cautious of overloading: the shelf should not be fully loaded to prevent tipping and wobbling.
