ᐅ Use of BILLY Shelving in Damp Rooms – Opportunities and Limitations
Created on: 2 Oct 2023 08:43
geavdi56Hello everyone,
I am currently looking into how suitable the IKEA BILLY bookshelf is for use in damp environments. I am particularly interested in the possibilities and limitations of using this classic bookshelf in areas such as bathrooms or basements, where humidity levels are higher.
I consider the following topics important:
- How does the bookshelf material react to moisture? Are there known issues such as warping, swelling, or mold growth?
- What measures can be taken to make the bookshelf as moisture-resistant as possible or to protect it?
- Where are the practical limits beyond which it is better to consider alternative solutions?
I would greatly appreciate any experience reports or professional assessments to help me make an informed decision. Thank you in advance!
Hello geavdi56,
a BILLY shelf in a damp area sounds at first like an experiment called ‘cabinet meets sauna’ 😂. Jokes aside – the standard BILLY shelf is made of coated particle board. It can handle some moisture but definitely isn’t designed for constant high humidity or water splashes.
From my experience: if you want to use the shelf in a bathroom, it’s best to place it away from direct water sources and possibly treat it with a water-repellent paint or varnish.
That’s exactly what happens: the edges swell, the material softens, and in the worst case, mold starts to grow.
However, with some preparation and a smart location, it can work out. Just be careful, otherwise you might soon have “muddy corners” instead of comfortable living space. 🙂
geavdi56 schrieb:
How does the shelf material react to moisture? Are there known issues like warping, swelling, or mold growth?
The fundamental issue with BILLY in damp rooms is that the particleboard is NOT designed for high humidity. So we are far from having “furniture for the bathroom” here.
What I find problematic is the common assumption that surface coating alone can solve the issue.
Such a treatment can help but does not address the core problem: the core material absorbs moisture in high humidity, swells, and loses stability.
If I were you, I would look for alternatives, such as furniture specifically made for damp rooms from solid wood with appropriate surface sealing, or completely water-resistant plastic or metal shelves.
Your question about possibilities is valid, but the limitations should be taken seriously.
Otherwise, good luck with your planning. Sometimes small upfront investments are better than repairing moisture damage later.
Trate47 schrieb:
Treat with a water-repellent paint or varnish
Hey everyone!
I find this topic really interesting! I have my BILLY shelf in the basement, and it’s not completely dry down there, but also not wet – more like a semi-dry climate. And you know what? It’s holding up great!
So I think with some smart combinations, you can really get lucky! 🙂 For example, you can combine the shelf with moisture absorbers, ventilate regularly, and avoid direct water.
Sure, that’s true. But especially if you’re not setting up a large bathroom or sauna, you can still get a lot out of the BILLY shelf.
Just give it a try and feel free to share here how it works for you! That will definitely motivate others too :-)
kasan schrieb:
Furniture specifically designed for damp rooms is often more expensive but worth it in the long run.
I would like to provide a more detailed perspective:
The key issue when using a BILLY shelf unit in damp environments is not just short-term moisture resistance, but especially long-term durability and hygiene.
Such measures are certainly helpful, but it is often underestimated that even minor exposure to moisture will eventually lead to material fatigue.
The risk of mold should not be overlooked either. Particleboard not only provides a breeding ground for fungi but moisture actually promotes their growth.
For a final assessment, it is important to consider the actual level of moisture exposure and whether the environment is climatically controlled (e.g., ventilation, heating source).
In summary: You can use the BILLY shelf temporarily and with caution, but for consistently high moisture levels, it is advisable to plan with furniture or systems designed for those conditions.
vinpau schrieb:
combine with moisture absorbers and ventilate regularly
