ᐅ BILLY Shelf to Level Uneven Floors – Any Tips?
Created on: 20 Feb 2023 08:37
jordikeo
jordikeo
20 Feb 2023 08:37
I have a BILLY bookshelf from IKEA at home that I would like to level on an uneven floor. I have noticed that the floor has some slight holes or depressions in certain areas, which make the shelf a bit unstable or cause it to not stand evenly.
My question is: What are the best and most practical methods to ensure the stability and leveling of a BILLY bookshelf when the floor has irregularities like small holes or dips? Which materials or tools would you recommend to safely and permanently stabilize the shelf without it wobbling or tipping over?
I prefer not to make any major structural changes but rather work with aids or small adjustments.
Thank you for your advice!
Tatovin
20 Feb 2023 10:02
the best option here is to use special furniture pads that you place between the leg and the floor. Rubber pads or small felt glides help to even out irregularities and provide stability. Alternatively, wooden shims can be used if the difference in height is greater.
kaubi
20 Feb 2023 14:45
jordikeo schrieb:
My question is: What are the best and most practical methods to ensure the stability and alignment of a BILLY shelf unit when the floor has irregularities like small holes or depressions?
To address this thoroughly, I would recommend first measuring the exact locations and depths of the floor irregularities. Depending on how large the depressions are, the approach will vary.
Here are some step-by-step suggestions:
1. Measurement: Use a spirit level and mark the affected areas on the floor. Small holes up to about 3 mm (1/8 inch) can be easily compensated with felt or rubber pads.
2. Larger irregularities: For deeper depressions, you can place small wedges or sturdy wooden shims under the shelf feet. These come in various materials, such as plastic, wood, or rubber.
3. For long-term stability: There are also adjustable furniture feet that can be attached to the shelf and precisely set to the desired height. These feet can be adjusted with millimeter accuracy.
4. If the floor is too damaged, consider placing a thin leveling board in front of the shelf, for example made of plywood or MDF, cut to fit.
Have you already checked the exact size of the holes or depressions? That would help provide a more precise answer. 🙂
Mufato
20 Feb 2023 15:10
If the holes are small, simply use larger felt pads. If that is not enough, wood glue combined with layered wooden shims can help. A quick solution without much effort.
Keatondra
21 Feb 2023 09:18
kaubi schrieb:
There are also specially adjustable furniture legs that you can attach to a shelf and adjust as needed.
Exactly, these are actually the best solutions, especially if your floor is uneven. You can simply screw or stick these feet under the shelf legs, depending on the model.
Sometimes adjustable plastic screws that you can turn individually to level the shelf also work.
If you want to be extra safe, you should also secure the shelf to the wall to prevent it from tipping over permanently. I especially recommend this for BILLY shelves, as it is important for safety.
If you like, I can also give you tips on where to find these adjustable feet and what to look for when buying them.
jordikeo
21 Feb 2023 11:29
kaubi schrieb:
Have you already checked the exact size of the holes or indentations?
Thank you for your detailed answer! The indentations are about 5 to 7 mm (0.2 to 0.3 inches) deep, so larger than I initially thought. They are rather localized, not across the entire surface.
Mufato schrieb:
If the holes are small, just use larger felt pads.
I guess the felt pads probably don’t provide that much depth, do they?
Keatondra schrieb:
These feet can simply be screwed or glued under the shelf feet.
I find the idea of adjustable feet very interesting, but I wonder how to do this best with the BILLY shelf without affecting its appearance? Has anyone had experience with this?
Also, one more question: If I use small wooden wedges – could these deform over time due to the weight and thus not be a long-term solution?
