ᐅ BILLY Shelf Tips for First-Time Users – What Should You Avoid?
Created on: 18 Nov 2022 19:02
HUDSON
Hello everyone, I’m planning to assemble my first Billy bookcase from IKEA soon and would like to gather some tips on what beginners should definitely avoid.
I understand the basics, but there are some details that are easy to overlook, such as stabilization, weight limits, or the best approach to assembling it.
What common mistakes have you or other users encountered that might not be obvious without experience? Are there any tips or recommendations to help build the bookcase so that it remains stable, safe, and durable over time?
I look forward to your insights and advice!
Jonas66
19 Nov 2022 11:45
In short: Always install wall fixings, do not place heavy items on the upper floors, and properly mount the back panel. Otherwise, problems may arise later.
barle
21 Nov 2022 08:22
From my own experience: Avoid placing the BILLY shelf flush against the wall at the back without securing it. It may seem stable but can tip over easily. I also tried using cheap wall anchors, which turned out to be a bad idea.
Also, make sure to sort all parts and carefully check them against the instructions before starting assembly. Mistakes often happen when you start building right away without having all screws and panels prepared.
ju_ren
21 Nov 2022 21:37
It is also important not to place the shelf permanently on carpet, as this can affect its stability. It is better to use a solid base instead. Additionally, it is advisable to properly pre-drill the holes for wall mounting.
Jukin
22 Nov 2022 18:18
This is a common issue, so definitely keep it in mind! Even if the shelf seems small, it’s better to be safe and anchor it to the wall.
ju_ren schrieb:
Don’t place the shelf permanently on carpeted flooring
That’s true – carpet can cause the shelf to wobble because the surface isn’t completely stable. Alternatively, you can put small rubber pads under the shelf feet to improve grip and also protect the floor.
My tip: Be patient during assembly and follow the instructions carefully. This helps avoid most beginner mistakes and ensures long-lasting stability :-)
