ᐅ BILLY Shelf Shapes and Variants – Choosing the Most Stable Option
Created on: 21 Sep 2019 08:13
MALERE
Hello everyone, I am looking for the most stable version of the well-known Billy bookshelf from IKEA. There are different shapes, sizes, and extensions available, but which ones are the most recommended in terms of stability and durability? I am particularly interested in the differences between the standard models, the narrower versions, and the ones with glass or back panels. Are there especially load-bearing versions or options to improve stability with accessories? Who has practical experience and can offer recommendations?
Laukau5
21 Sep 2019 11:02
Takutau schrieb:
The back panel on all models is made of thin hardboard, but without it the structure quickly becomes unstable.
I completely agree. Without the back panel, the torsional rigidity is greatly reduced. For tall shelving units, it is advisable to reinforce the wall panels with additional brackets. Also, the choice of screws affects stability— IKEAs usually uses relatively short screws. So, anyone wanting maximum durability should use high-quality screws and wall anchors.
By the way: For heavy loads, IKEA offers accessory kits, such as metal braces for additional reinforcement. Has anyone here tried those before?
Chendu
21 Sep 2019 11:19
Metal brackets can significantly increase stability, especially if the shelf cannot be placed close to the wall. Otherwise, the traditional wall mounting with the included brackets proves reliable.
MALERE
22 Sep 2019 07:45
Thank you very much for the detailed information so far! I have an additional question: Are there any differences in stability between the various heights of the Billy shelves, especially for the tallest versions (about 202 cm (79 inches))? I am considering buying such a tall shelf for books and folders. Is it sufficient to simply choose the standard version and secure it to the wall, or would it be better to opt for a wider, shorter version and possibly place several shelves side by side? How about the risk of tipping over?
edisondan
22 Sep 2019 08:15
Basically, the stability of taller BILLY shelves (202 cm (79.5 inches)) mainly depends on wall mounting. The tipping resistance without wall attachment is not sufficient, regardless of whether the shelf is wide or narrow. The wider version provides a larger base area but only slightly reduces the risk when not mounted to a wall. The key factors are a sturdy back panel, proper wall fixing, and even load distribution. For heavy books, it is advisable not to overload the lower shelves and to store heavier items as low as possible.
PERON
22 Sep 2019 08:42
MALERE schrieb:
What about the tipping risk?
I think every owner is familiar with that tipping feeling 🙂 As edisondan says, wall mounting is absolutely crucial here. It’s better to firmly screw the shelf in with pride than to wake up later to a subtle “tip” in the living room 😄. I would also recommend always placing the tallest shelves next to more stable pieces of furniture. Stability through proximity, so to speak.
Takutau
22 Sep 2019 09:10
PERON schrieb:
Stability through the neighborhood, so to speak.
Well said! From a mechanical perspective, lateral forces are better distributed to the adjacent furniture, which reduces twisting. Simple measures like using connectors or wooden strips between furniture pieces can also add extra stability. This approach is especially worthwhile when arranging furniture in small rooms.
