ᐅ BILLY Shelf Shapes and Variants – Choosing the Most Stable Option
Created on: 21 Sep 2019 08:13
MALEREHello everyone, I am looking for the most stable version of the well-known Billy bookshelf from IKEA. There are different shapes, sizes, and extensions available, but which ones are the most recommended in terms of stability and durability? I am particularly interested in the differences between the standard models, the narrower versions, and the ones with glass or back panels. Are there especially load-bearing versions or options to improve stability with accessories? Who has practical experience and can offer recommendations?
To thoroughly address the stability of BILLY shelving units, we should first consider their load limits and materials. BILLY shelves are typically made from particleboard with a thin melamine coating, which is cost-effective in the furniture industry but less sturdy than solid wood. The 80cm (31.5 inches) wide models are significantly more stable than the narrower 40cm (16 inches) versions, especially when the back panel is made of rigid hardboard. Wall mounting is also important, as taller units are prone to tipping if not secured properly. Those planning to store heavy items should consider using additional units with reinforcements or combining them with stability brackets. Models with glass back panels or doors are primarily for aesthetic purposes and do not provide extra stability.
I have the wide version of the BILLY at home and can say: the stability is excellent, especially when it’s firmly fixed to the wall! 🙂 A small tip from me: definitely use the wall mounting brackets included by IKEA – this provides a sense of security, especially if there are children or pets in the house 😉. Small rubber pads under the feet can also help protect the floor while improving grip.
In addition to the previous statements: Generally, the stability of BILLY shelves strongly depends on whether they are assembled correctly and secured to the wall. The narrower versions are less load-bearing and tend to wobble more easily but are suitable for lighter loads or tight spaces. The back panel on all models is made of thin hardboard, but without it, the structure quickly becomes unstable. For heavy loads, shelf boards should not be overloaded, with a maximum of 10-15 kg (22-33 lbs) per section. Additionally, load distributors or extra screws can be used to reinforce the shelves.
