ᐅ How to Screw in BILLY Shelf Screws Without Damage: Tips and Tricks
Created on: 10 May 2020 09:07
ewensan
Hello everyone, I’m currently assembling a Billy bookshelf and I’m wondering how to screw in the screws without damaging the material. Since the wood is relatively soft and the holes are pre-drilled, there is a high risk of the wood splitting or the screws being over-tightened, which could make the shelf unstable. Do you have any proven tips or tricks on how to screw them in properly without damaging the shelves or compromising stability? For those familiar with this shelf: is it more about pre-drilling, using the right screwdriver, or the timing of screwing? Thanks!
PIERCE
12 May 2020 08:38
faso31 schrieb:
I wonder if it might be more sensible to use torque-limiting screws instead of friction-reducing agents.
Definitely, that is very important when using a cordless drill. It is often underestimated how easily the material can be damaged otherwise.
DUUS32
13 May 2020 14:21
For everyone who feels a bit unsure: take your time and proceed step by step. I was nervous at first because, of course, you don’t want to cause any damage, but with a slowly turned screwdriver and a lot of patience, you can manage it well.
And if a screw feels a bit tight, it’s better to stop briefly, turn it back, and reposition it. Gaining confidence in the materials and tools helps a lot :-)
