ᐅ BILLY Shelf Paint Scratched – Touch-Up Marker or Repaint?
Created on: 9 Jul 2016 19:37
NILSTI
NILSTI
9 Jul 2016 19:37
I have noticed several small scratches in the finish of my Billy bookshelf from IKEA. Since the finish is applied quite thinly, the damage is immediately visible. My question is, what would be more practical in this case: using a touch-up paint pen for quick repairs or repainting the entire bookshelf?
On the one hand, I want to keep the effort as low as possible, but on the other hand, the result should be neat and durable.
Has anyone had experience with paint pens specifically designed for furniture, and how well do they really hold up? Or, from a long-term perspective, does it make more sense to sand the bookshelf down and repaint it completely, perhaps using a special furniture or polyurethane varnish?
What are your thoughts, especially regarding the appearance after touch-up painting compared to a full repaint? Thanks in advance for any advice!
TEKIN
9 Jul 2016 20:12
Hello NILSTI,
Basically, touch-up paint pens are intended for small damages like scratches to quickly improve the appearance of minor areas and provide superficial corrosion protection. They are usually alkyd-based or acrylic paint and dry quickly.
BILLY shelves are typically made of particleboard with a melamine or lacquer coating. The lacquer is generally very thin and somewhat sensitive.
A paint pen can offer a quick fix but is only suitable for small areas of damage and when the color matches exactly. Durability under stress is limited, and the finish tends to become dull.
A full repaint after light sanding ensures a uniform surface, better protection, and long-lasting durability. For this, you should use a synthetic resin paint or special furniture lacquer.
Conclusion: For a few small scratches, a paint pen is practical. For larger or multiple damages, I recommend repainting, as it looks better and lasts longer.
INGRID34
9 Jul 2016 22:45
TEKIN schrieb:
For a few minor scratches, a touch-up pen is practical.
I can only agree with that. Touch-up pens are quick and helpful, but for multiple or larger scratches, repainting is worth the effort.
neo59
10 Jul 2016 00:07
TEKIN schrieb:
Durability is limited under stress and tends to dull.
I see this differently, as it depends on the type of use. If the shelf is often moved around or heavy objects are dragged across it, then a touch-up pen is indeed an insufficient solution. On the other hand, the question arises whether a full repaint might involve more time and material costs, especially if the shelf shows hardly any visible damage.
Also, you should consider that before repainting, the old paint must be removed or sanded down to ensure proper adhesion. Most commercially available furniture paints are not exactly cheap either.
Therefore: Don’t expect perfection from a touch-up pen, but in many cases, it’s completely adequate. However, if appearance and durability of the surface are important to you, a proper repaint would be the better option.
erikpu
10 Jul 2016 09:16
Hello NILSTI,
I’ll give you an overview first:
Touch-up pens are convenient for small repairs, but their color accuracy is often limited. Especially with BILLY shelves, which frequently have a white matte or satin finish, even slight color differences and variations in gloss can be very noticeable.
Here’s how to repaint:
- Lightly sand the shelf with fine sandpaper (grit 320-400) to roughen the surface.
- Remove surface dust, ideally with a lint-free cloth.
- Use a suitable furniture or alkyd enamel paint that matches the original color tone.
The result looks more uniform, and the surface becomes more durable.
Alternatively, you can use special furniture lacquer repair kits. These kits usually include filler putty, fine sandpaper, and matching mini paints. This is a hybrid solution that works better than just a touch-up pen but requires less effort than a full repaint.
If the scratches are very small and appearance is not critical, a touch-up pen is sufficient. However, if the shelf is visible in everyday use and you want an optimal result, I would recommend sanding and repainting.
George
11 Jul 2016 15:28
NILSTI schrieb:
Does anyone have experience with paint touch-up pens specifically for furniture and how well they actually hold up?
I have used paint touch-up pens, and they hold up fairly well under light use. However, with heavy use, the finish deteriorates quickly.
erikpu schrieb:
Alternatively, you can use specialized repair kits for furniture finishes.
These kits are often a good compromise if you don’t want to refinish the entire surface.
