ᐅ BILLY bookshelf doors tend to tilt – how to reinforce them?
Created on: 24 Oct 2016 19:03
Jackflo
Hello everyone, I have a Billy bookshelf with doors that, after a while, tend to tilt on their own, so they no longer close straight but hang slightly crooked. Does anyone have experience with reinforcing or stabilizing the doors on this type of shelf to keep them straight for a long time? I suspect it has to do with the door hinge mechanism or the material, but I would prefer not to just buy new hinges without a well-founded solution. Are there any affordable tips or modifications for a lasting result?
pautanner
25 Oct 2016 11:04
Jackflo schrieb:
Consider 4mm MDF, a good compromise between weight and stability.
Exactly, and if you carefully glue and clamp it with some wood glue, you basically have a fantastic door that won’t warp or twist stubbornly anymore. No magic involved, just a lot of know-how 😉 Good luck!
enrique7
26 Oct 2016 07:51
I would like to return to the fundamental question: Reinforcement only makes sense if the cause of the deformation is actually a lack of material stiffness. Have you checked whether your doors might have warped due to uneven moisture or improper installation? Because in that case, the problem with climate control and installation quality needs to be addressed first.
Jackflo
26 Oct 2016 08:15
enrique7 schrieb:
Adding reinforcement only makes sense if the cause of the deformation is actually insufficient material stiffness.
Thank you, that’s a really important point! I have checked the moisture levels, and the shelf is placed in a well-heated room without significant fluctuations. I assembled it myself, so the installation should be precise, but I will double-check with a spirit level tomorrow and add shims if necessary. After that, I will probably try reinforcing it with MDF and keep you posted.
bufukin
26 Oct 2016 14:45
In summary: The best way to keep the BILLY doors permanently straight is through a combination of:
- Precise vertical alignment of the shelving unit
- Secure attachment and, if necessary, reinforcement of the hinges
- Targeted stiffening of the door interiors, for example with 4 mm (0.16 inch) MDF
This approach has proven effective and sustainably reduces warping.
