ᐅ BILLY Bookcase Alternative Shelves – Which Material?
Created on: 11 Aug 2020 14:07
Bo-be66
I have a Billy bookshelf from IKEA and would like to try an alternative material for the shelves instead of the usual particleboard. Currently, the shelves are typically made of coated particleboard with a thin melamine layer, which works well for many purposes, but I am interested in more durable, possibly sturdier, or visually more appealing materials.
I would appreciate any experiences and recommendations regarding suitable replacement materials for the BILLY shelves. The material should be relatively easy to work with (cutting, etc.), remain stable, and not add too much thickness, so the bookshelf does not look too bulky.
Have you ever used solid wood, plywood, MDF, or other materials for shelves? How durable are they, what about their appearance, and do you have any practical tips for selecting or working with them?
I look forward to your opinions and advice!
Fitigu
13 Aug 2020 09:03
One more tip regarding the work: Always use sharp tools for cutouts and edge milling, as plywood tends to splinter or tear out, especially along the edges.
For sealing, varnishes or hard wax oils are suitable, as they protect the surface against moisture and dirt.
In situations with moisture exposure, applying a varnish is almost mandatory.
Takutau
13 Aug 2020 09:47
relupa schrieb:
I am honestly impressed by the feel.
I understand that well; plywood has a very pleasant texture and a natural wood appearance.
If desired, you can also create an eco-friendly and sustainable surface by lightly sanding and then treating it with linseed oil or beeswax.
Good luck with your project, Bo-be66! 🙂
