ᐅ Billy Regal Top usage tips for improved stability.
Created on: 6 Mar 2023 18:07
Rosssi
Hello everyone, I recently bought a Billy bookshelf from IKEA and want to use it as stably as possible. The construction is quite simple, but I’m wondering what tips there are to ensure maximum stability, especially when storing many or rather heavy books and folders. Are there any proven tricks for assembly, additions, or modifications to consider? I’m already aware of the usual advice like wall anchoring, but maybe there are some less well-known tips? Thank you in advance!
LEEJU
7 Mar 2023 09:05
For a simple and effective stabilization, reinforce the back panel with a plywood sheet. Additionally, carefully adjust all shelves to ensure they do not wobble. Use wall brackets and, optionally, secure the bottom feet with small wedges.
daalessio
7 Mar 2023 10:38
One thing that is often underestimated is tightening the screws precisely during assembly. Do not warp the shelf by over-tightening individual screws. Instead, tighten all screws gradually and evenly to avoid deformation. I also recommend not replacing the supplied shelves with your own thin alternatives – the original shelves are specifically designed to be structurally stable.
reni45
8 Mar 2023 11:59
For additional support, special angle brackets can be attached to the cabinet and the wall. This is especially recommended if the shelf will be heavily loaded at a great height. Do not underestimate the wall mounting, as tipping is the greatest risk.
INGRID34
9 Mar 2023 14:22
The balance between easy assembly and stability is always a challenge with Billy. My advice: Before assembly, check if the floor surface is level and, if necessary, use small cork or plastic shims to even out any unevenness. This will make the shelf stand more securely and reduce the risk of tipping.
