ᐅ Billy Regal Top usage tips for improved stability.
Created on: 6 Mar 2023 18:07
Rosssi
Rosssi
6 Mar 2023 18:07
Hello everyone, I recently bought a Billy bookshelf from IKEA and want to use it as stably as possible. The construction is quite simple, but I’m wondering what tips there are to ensure maximum stability, especially when storing many or rather heavy books and folders. Are there any proven tricks for assembly, additions, or modifications to consider? I’m already aware of the usual advice like wall anchoring, but maybe there are some less well-known tips? Thank you in advance!
nonlau35
6 Mar 2023 18:15
Wall mounting is mandatory to prevent tipping. Always use the supplied anchors and screws suitable for your wall type. Additionally, you can attach small felt pads at the bottom to improve stability.
Gofoman
6 Mar 2023 18:52
I always find it surprising how many people focus solely on wall mounting when it comes to the Billy shelf, even though it has much more potential. For example, one should consider whether these shelves are fundamentally built too lightly for their intended use—why not reinforce the back panel with metal plates? Or use solid wood shelves? Most people overlook that IKEA primarily aims for affordable mass production here, not a long-term solution. The stability could be significantly improved by adjusting the materials used.
flo-Theres
6 Mar 2023 19:33
A good point to consider is load distribution. Ideally, the Billy shelf should be loaded so that the heaviest items are placed at the bottom. This improves stability. Additionally, reinforcing the back panel with extra battens or a thin plywood sheet screwed flush onto the existing back panel is worthwhile. This significantly increases torsional stiffness.
Rosssi
7 Mar 2023 07:41
Gofoman schrieb:
Why not reinforce the back panel with metal sheets?
That’s an interesting approach. Metal sheets sound sturdy, but how do you assess the weight ratio and the effort involved? Can this be done without special tools? I’m also curious whether this would make the shelf too heavy or bulky, making wall mounting more difficult. Are there perhaps alternatives to metal that are easier to attach?
gekira
7 Mar 2023 08:47
To stabilize Billy shelves, I recommend the following approach: First, ensure proper wall mounting using suitable wall anchors, as this is essential. Second, distribute the loads so that heavy items are stored at the bottom. Third, use additional reinforcements for the back panel, such as plywood panels at least 6mm (0.24 inches) thick, screwed onto the existing back panel. Metal plates are also an option, but they significantly increase costs and effort, although they offer the best protection against deformation. Fourth, when in doubt, square timber battens in the corners are useful to improve the frame’s rigidity.
