Hello everyone, I’m preparing for my move and have purchased a Billy bookcase from IKEA that I plan to take partially into my new room. Now I’m wondering: how well does the Billy bookcase disassemble without damaging the material or compromising stability later on?
I’m especially interested in whether the back panel can be easily removed, since it is often attached with small nails, and how difficult it is to take apart the side panels and shelves. Are there any specific tools you really need, or is this something a layperson can usually manage?
Also, does anyone have experience fully disassembling the bookcase and then reassembling it so that it’s just as stable as before?
I would appreciate any tips, tricks, and experiences to help make my move as smooth and stress-free as possible!
Hey Dibill30, I’m familiar with your situation – the Billy shelf is basically the ultimate moving buddy ;-)
Regarding your question: Yes, the back panel can usually be removed quite easily since it’s typically attached with nails or sometimes staple-like fasteners. A flat tool like a putty knife or a small pry bar can help gently loosen the nails. But be careful not to tear the back panel.
To take apart the other parts – the shelves are often held in place with dowels and secured with screws. Using the right screwdriver (usually a Phillips or Allen key) should make this straightforward.
I’d recommend keeping all screws and dowels carefully when disassembling and laying out the parts step by step, so nothing gets lost for reassembly. And yes, if done properly, you can easily restore the stability.
Good luck, and remember: patience is key! 🙂
Hello Dibill30, I have disassembled and moved the Billy shelf several times, so I can share some experience with you:
The back panel is mainly responsible for the stability of the shelf. That’s why you should be especially careful when prying off the back panel to avoid any cracks. It’s best to use a thin, flat tool and work gradually, piece by piece.
Regarding tools: A Phillips screwdriver is usually sufficient since IKEA mainly uses cross-head screws. Sometimes a small Allen key is included, which you definitely shouldn’t lose.
When assembling, make sure all screws are tightened securely but not overly tight to prevent the material from splitting. If you completely disassemble the shelf, you can also check the dowels to see if they are still firmly in place or if they might need replacing.
My tip: If you plan to take the shelf apart multiple times, it’s worth practicing on a small section first to get a feel for the material. If you have any questions about the exact process, feel free to ask!
Alberto5119 Dec 2022 14:23I think it’s great that you’re putting so much thought into carefully disassembling your Billy bookshelf.
I can easily relate to how challenging a move can be and the desire to avoid unpleasant surprises when a favorite piece of furniture suddenly becomes wobbly or gets damaged.
What helped me was making small markings on each part after unscrewing them. This made it much easier later to identify which piece belonged where. It really reduced my uncertainty.
However, I also noticed that it’s best not to disassemble it too many times, as the chipboard at the joints can wear out over time. So my advice: be gentle and careful, and usually fully disassembling and reassembling the furniture once for a move works very well! Good luck!
tutan schrieb:
The back panel can usually be removed quite easily because it is only fixed with nails or sometimes stapled connectionsThat is correct, but I would like to point out that although removing the back panel is possible, the shelf loses significant stability without it.
sarlo schrieb:
The back panel is mainly responsible for the shelf’s stabilityExactly, which is why I would recommend keeping the back panel attached during transport and only disassembling the other parts. Otherwise, you risk warping or wobbling of the shelf after reassembly.
Additionally, especially with older Billy shelves, the material around the dowel joints may have loosened over the years. This means that disassembling and reassembling could lead to compromises in stability.
My recommendation is to take the shelf apart as much as possible but only remove the back panel if absolutely necessary to avoid major transport issues.
