ᐅ How to Reinforce Billy Regal Connector Brackets?
Created on: 9 Mar 2024 08:34
klamar
I am currently facing the problem of how to reinforce the connectors in the Billy shelf unit (IKEA). The joints between the individual shelves and the vertical sides feel a bit unstable to me, especially when I place heavy loads on them. I am interested in whether there are practical and, above all, durable solutions to strengthen these connection points without affecting the design or flexibility of the shelf.
Are there specific reinforcement elements that can be retrofitted, or rather DIY solutions (e.g., screws, brackets, glue)? I want to avoid losing stability over time or making the shelf wobbly. Thanks for any tips and experiences!
neoren
9 Mar 2024 11:14
Metal brackets are the preferred choice for many who want stability with minimal effort. Use 4x35 mm (approximately 5/32x1 3/8 inch) screws along with glue. This holds well.
If desired, small wooden strips can be added later, but usually this is sufficient.
Gloriagl10
9 Mar 2024 12:01
Another idea: If you can securely mount the shelf to a wall, additionally fasten it with brackets or special shelf supports. This significantly reduces the strain on the joints and increases safety.
Although this is not a direct reinforcement of the joints themselves, it will save you from long-term issues with wobbling.
kautra
9 Mar 2024 12:37
To reinforce Billy connectors, I recommend:
- Installing metal brackets 40x40 mm (1.6x1.6 inches) or 50x50 mm (2x2 inches) on the inside
- Choosing screws appropriate for the brackets (usually 3.5-4 mm (0.14-0.16 inches) thick)
- Using wood glue for a permanent bond
A simple, effective combination.
Nathanaelk
10 Mar 2024 08:05
klamar schrieb:
The load will be up to 25 kg per shelf board
For 25 kg (55 lbs) per board, I wouldn’t take any risks. Make sure that, in addition to reinforcing the joints, the back panel of the shelf is securely fixed, as it significantly contributes to overall stability.
Metal angle brackets (at least 40x40 mm (1.6x1.6 inches)) at all corners, combined with high-quality wood glue, provide a strong and reliable solution. The screws used for the brackets should be at least 35 mm (1.4 inches) long so they grip well in the shelf wood without being too short.
If you have the time: after gluing, allow a curing period of at least 12 to 24 hours before applying any load. This will improve durability and help prevent long-term sagging or loosening of the joints.
LEEJU
10 Mar 2024 08:26
Attach metal brackets from the inside, apply wood glue, then use 4x35 mm (4x1.4 inch) screws. Done.
klamar
10 Mar 2024 09:10
Great, then I’ll try the combination of angle brackets and glue.
Thanks to everyone for the clear tips and explanations, especially to you, Nathanaelk, for the detailed information on curing and the back panel.
If anyone has a recommendation for the right type of screw for chipboard (e.g., special SPAX or regular wood screws), I would appreciate it.
If not, I’ll get back to you once I have implemented it.
