ᐅ Cleaning of shelving units in case of heavy dust accumulation.
Created on: 26 Oct 2022 08:17
Liriti
I have a wooden Billy bookcase in my living room, which gets quite dusty due to its location next to an open window. Especially when there is a lot of dust, I am wondering about the best way to clean the bookcase without damaging the surface or causing water stains. Does anyone know of specific methods or recommended products for cleaning Billy bookcases with heavy dust buildup? I am particularly interested in tips on how to remove the dust effectively without harming the wood, and how to care for the bookcase afterward to reduce the speed at which dust settles again. Thank you in advance!
Liriti
27 Oct 2022 07:18
Thank you for the tips so far.
However, I’m wondering if anyone here has experience with using a vacuum cleaner together with a microfiber cloth for everyday cleaning. The vacuum cleaner is obviously more effective, but does it leave visible marks or even scratches? And is a special attachment necessary?
Also, I’d be interested to know if anyone is aware of a method that is particularly useful for heavy dust build-up near open windows, such as occasional wiping with specific products or special care treatments for wooden shelves.
meoreo
27 Oct 2022 08:35
A vacuum cleaner with a soft upholstery nozzle is best to use. Avoid sharp suction heads. Scratches are usually not a concern if you work carefully.
Regular wiping is generally sufficient; no aggressive cleaning agents are necessary.
NoValentin
27 Oct 2022 09:02
I sometimes use a water and vinegar solution diluted 1:10 on a microfiber cloth for stubborn dust, but without wiping it wet. Afterwards, let it dry thoroughly.
This method is gentle and cleans effectively without damaging the coating.
nonpra
27 Oct 2022 09:27
I would advise against using vinegar, as it can dull the surface.
It is better to use gentle, neutral pH cleaning agents and apply them sparingly.
For heavy dust, regular vacuuming combined with dry wiping is more effective.
Ixfu2
28 Oct 2022 10:15
In addition to cleaning, the shelf can be treated with furniture polish once or twice a year. This reduces static electricity buildup and, consequently, dust accumulation.
However, avoid polishing too often to prevent damage to the finish.
