ᐅ Billy shelf installation assistance via videos – which ones are recommended?
Created on: 30 Nov 2024 18:27
Mantar
Mantar
30 Nov 2024 18:27
I’m currently facing the challenge of assembling a Billy bookshelf from Ikea. Since I want to help both with the assembly and leveling, I’m looking for good tutorial videos. I’m specifically interested in detailed or especially well-explained videos that guide you through the assembly step by step and also point out common mistakes or pitfalls.
It’s important to me that the videos are practical, possibly including tips on how to handle screws and shelves correctly, rather than just reading out the standard instructions. Are there any personal recommendations in this forum, or even experienced “Billy” experts with favorite videos?
I would really appreciate detailed suggestions for channels or specific clips!
Thanks in advance!
Filippo
1 Dec 2024 09:04
Hello Mantar,
I think your approach of looking for a well-explained video tutorial is very sensible, especially since small mistakes often creep in when assembling Billy-style shelves, which can later cause unstable constructions. If you like, I can share some tips on how I proceed and which YouTube channels I find particularly helpful:
1. Systematically check the parts before assembling: Before you start screwing, sort all the pieces and compare them with the exploded diagram. This helps avoid misplacements that are often overlooked in videos.
2. My favorite is the channel by "Handwerker Tom." He has several videos about the Billy shelf that not only show the assembly but also explain the correct installation of the back panel, which is often done carelessly, and critically discuss the alignment of the shelves under load.
3. Another recommendation is "DIY mit Petra" – she offers good advice on properly installing dowels and screws, which is especially important with the Billy shelf if you also plan to fix it to the wall.
4. Make sure to watch videos that show the complete assembly instead of just quick clips. This way, you get a better sense of the order and handling of certain parts.
One more question: Do you have a cordless drill, or are you working with hand tools? This really affects the speed and accuracy of the assembly.
I have often experienced that improper tightening of screws or clamps leads to play later on – this is very well explained in "Handwerker Tom’s" videos.
If you’d like, I can send you more precise links after your feedback.
Filippo
Elijah42
1 Dec 2024 10:16
Mantar, check out the videos by "Ikea Aufbauhelfer" on YouTube. They are short, clear, and show the assembly of the Billy step by step. Recommended if you don’t have time for long tutorials.
Nabla64
2 Dec 2024 12:39
Filippo schrieb:
My favorite is the channel "Handwerker Tom." He has several videos about the Billy bookshelf that not only show the assembly but also explain the correct way to mount the back panel, which is often done poorly, and critically covers how to level the shelves under load.
Good tip! Additionally, I’d like to share a brief guide to avoid common mistakes during assembly that I always follow:
1. Always insert the back panel first and fix it with small nails. It provides the necessary stability for the bookshelf.
2. When inserting the dowels, don’t use a hammer with full force. The holes are precise—excessive pressure can damage the wood particles.
3. Always screw in carefully to avoid thread damage. If the pilot hole is too deep, the bookshelf can become wobbly quickly.
4. Use a spirit level when adjusting the shelves; especially with multiple shelves, even alignment is important.
5. After assembly, double-check all screws to ensure they are tight.
If you watch videos covering these points, you should be able to assemble the Billy bookshelf very solidly. Also, look for videos that demonstrate assembly with realistic loads like books or decorations to see direct load tests.
Best regards, Nabla64
Davidleo
3 Dec 2024 14:51
Great topic! I know a few people who are very satisfied with the videos from the channel "Möbel Meisterei." They are really well made, highly motivating, and precise. 🙂
Elijah42 schrieb:
They are short, precise, and show the Billy assembly step by step.
But I have to say, for some, the more detailed version is definitely worth it! "Möbel Meisterei" also explains many tips, like how to position the shelf correctly in the room to ensure it stands very stable.
I immediately gained more confidence and built my first Billy shelf completely on my own – without stress and with a lot of fun!
So – just take a look and get started, you can do it ;-) !!!
