ᐅ Best overall smart home system
Created on: 26 Aug 2022 09:24
TaiiTvv
I am looking for a comprehensive smart home platform that can integrate devices from different manufacturers.
So far, I have come across the following options:
Home Assistant
OpenHAB
ioBroker
Which of these platforms is the best or most widely used?
It is important to me that it runs stably and allows for creating good automations.
Additionally, there should be a smartphone app available that can be used on the go to control the smart home or at least check the status of devices remotely.
Are all of these programs open source and available for free?
Which of these platforms would you recommend, or should we perhaps consider WiButler or Homee, which also support various wireless standards?
hanse987
30 Aug 2022 20:18
Araknis schrieb:
But on a different note... @TaiiTvv isn’t possibly related to @Taitv789 (and a few others), is he? 😉
No idea if he is Taitv789, but in the submitted floor plan, he is the semi-detached partner of Pacc666. 😉
https://www.hausbau-forum.de/threads/welches-smarthome-system-fuer-unseren-neubau.43819/page-16#post-587373
Araknis30 Aug 2022 22:14
This must be an extremely smart home–oriented community.
TaiiTvv
31 Aug 2022 07:29
Mycraft schrieb:
- Glass switch? Well, if you like it. I know they are popular, but mainly because of the price.
I actually don’t find them that bad visually, and the price is especially attractive at the beginning.
Mycraft schrieb:
Weather station, yes, having one is necessary; usually you can’t really talk about any kind of automation without it (eyes and ears).
Yes, a weather station was mandatory for us as well, mainly to control shading effectively or to lower the roller shutters at night or when windows are open/when away.
There is probably a lot more possible.
Mycraft schrieb:
Underfloor heating, again manually controlled? Ideally, it should regulate itself without external intervention, certainly not by a manual switch.
The underfloor heating is supposed to regulate itself automatically; I only imagined being able to change the target temperature using the glass switch.
Our new development will be fully connected to district heating (so no separate heating system in the basement).
Mycraft schrieb:
What do you mean by integrating it? For lighting, most people only consider on/off or maybe dimming, and that mostly by switch presses, so conventional systems would work just as well.
Are my expectations too low for KNX to be worthwhile in our case?
I’ve envisioned the following automations:
Automatic shading in summer
Automatic roller shutters, e.g. at sunset or when a certain lux level is dropped, with lockout protection for the terrace (which only works with window sensors)
Scenes like cinema mode, where certain lights turn on and the roller shutters lower by a certain percentage
Controlling stairway and hallway lighting without switches, using motion detectors
But honestly, when it comes to everything based on motion detectors, I can’t quite imagine it yet without experience.
Mycraft31 Aug 2022 09:03
TaiiTvv schrieb:
Our new housing development will be fully connected to district heating (there is no individual heating system in the basement)
You would need to look closely at how the system is ultimately designed. Even with district heating, there is relatively little to control in modern houses.
TaiiTvv schrieb:
Are my expectations too low for KNX to be worthwhile for us?
Contrary to common belief—expensive, luxury, etc.—KNX is always worthwhile, even in a 20 square meter (215 square feet) studio apartment.
This is generally strongly recommended, with or without KNX.
TaiiTvv schrieb:
Automatic roller shutters, for example at sunset or when a certain lux level is not reached, with lock-out protection for the terrace (which only works with window sensors)
There’s even much more possible.
TaiiTvv schrieb:
Controlling lighting in the stairwell and hallway without light switches (using presence detectors)
Then consider: human-centric lighting, for example when going to the toilet at night. Or nowadays quite common tunable white (CCT) lighting. In general, different lighting colors for different times and activities.
TaiiTvv schrieb:
But right now, without experience, I can't really imagine everything working with presence detectors
Not everything needs to. But definitely in the places you spend the most time and all the passage areas.
TaiiTvv
31 Aug 2022 13:28
Mycraft schrieb:
You would need to take a close look at how the system is ultimately set up. Even with local heating networks, there is relatively little to control in modern houses.
Should the underfloor heating then be integrated into the KNX system at all?
In our standard setup, we get an ERR (room temperature controller) for each room (which I believe is mandatory for KFW55).
Mycraft schrieb:
There is much more possible.
Can you give some examples? I probably don’t yet know the full potential of KNX.
Mycraft schrieb:
Not everything has to be controlled. But the rooms where you spend most of your time and all the hallways.
How can you configure the system so that the lights always turn on automatically as desired? It always depends on the situation and is often different and individual—I can’t really imagine a logic that can cover that.
netuser
31 Aug 2022 14:21
TaiiTvv schrieb:
Should the underfloor heating be integrated into KNX at all?
By default, we get an ERR for each room (which I believe is even mandatory for KFW55).
ERRs are not necessarily an advantage 😉
If possible and if there is still time, you should even try to be exempted from them....
TaiiTvv schrieb:
How can you set it so that the lights always turn on automatically as desired? That really depends on the situation and is often different and individual (I can’t imagine any logic that could cover that).
I personally wonder about that as well.
Aside from the fact that I couldn’t afford KNX in my house, automated lighting control is the last thing I miss. At least in a home. In my case, no meaningful automation can be implemented because depending on the situation and mood, I want to decide for myself whether I need light or prefer to walk in the dark.
The same goes for the roller shutter control, which in my case is indeed “smart” connected, but I still don’t set fixed times because we prefer to control it independently and as needed. At least when it comes to timing; it’s different for shading and dependencies on outdoor temperatures, for example....
