Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
11ant30 Aug 2019 12:38
Bauherr am L schrieb:
For a fan of exposed concrete, the combination of concrete + core insulation + concrete is probably a dream. But here in Germany, it is hardly known… at least that’s my impression. [...] The clinker brick curtain wall alone costs around 300€ net per square meter (approximately $320) ...
The 201X decade will go down in history as the era of fakes. A true exposed concrete* enthusiast would only consider solid concrete. This is no longer common in Germany, because its heyday ended roughly between 1975 and 1980, when environmental awareness entered the construction world. If someone wanted an interior "exposed concrete" look combined with a clinker brick curtain wall on the outside, it would be best to use the external layer as a clinker brick panel. However, the overlap between admirers of clinker bricks and fans of raw concrete is probably nonexistent.
*) The prefix "exposed" in front of concrete means that the material actually used structurally is visible on the surface—essentially "what you see is what you get." An "original fake" is naturally nonsense or only exists as a current trend. This should make everyone think, because according to history books, decadence is a sure indicator of the decline of a culture.
rick201830 Aug 2019 14:57
11ant put it very well. Solid in-situ concrete is a completely different matter than precast elements.
With precast, you have joints and no continuous surface. Molds used for in-situ concrete can also be used for precast, but a double hollow-wall that is later filled is not the same.
Our walls are also made of concrete, but cast in multiple stages, have joints, and are more uniform (unlike in-situ concrete). We like this appearance and have had long discussions with the manufacturers, casting samples...
In-situ concrete was ruled out due to cost and the complex window connections.
This morning, already half of the walls were in place. By tomorrow, all basement walls should be set. Things are progressing well currently )
Bird’s eye view of a construction site: foundation work with walls, material stacks, crane, and tarps.
11ant30 Aug 2019 16:47
rick2018 schrieb:
11ant put it very well. Solid in-situ concrete is a completely different matter than precast elements. Here, you have joints and no continuous appearance.
In-situ concrete or ready-mix concrete is a different topic; you probably mean site-cast concrete elements here. What I mainly meant is that "exposed" concrete refers to a solid cross-section, not just a cladding. The latter should rather be called "facing" concrete.
I'm too lazy to look it up right now: what is that "slot" shortly after the start of the retaining wall – is a gate meant to roll into it?
guckuck2
30 Aug 2019 16:53
Exposed concrete is primarily a quality grade based on appearance, which requires appropriate workmanship and a specific material mix. Thickness does not even come to mind, unless someone wants to engage in pointless semantics.
Steffen80
30 Aug 2019 17:18
The 201X decade will be remembered as the era of fakes. A true exposed concrete* enthusiast would only accept solid concrete. This is no longer common in Germany because its heyday ended around 1975 to 1980, when environmental awareness entered the construction world. If someone wanted an "exposed concrete" look indoors but with a brick curtain wall façade, it would be best to simply use the outer layer as a brick wall panel. But the overlap between fans of bricks on one hand and raw concrete on the other is probably nonexistent anyway.
*) The prefix "exposed" before concrete means that the actual structural material is visible on the surface — basically "what you see is what you get." An "authentic fake" is inherently nonsense or only exists as a current trend. This should actually make everyone think, because according to history books, decadence is a reliable indicator of a culture’s decline.
A very expensive building in our area is constructed entirely of concrete plus insulation (some phased material... I’m not sure what it’s called) with huge ceramic tiles in concrete look mounted on top. The façade alone is probably more expensive than our entire house, and they have been working on just the façade for several months already... BUT it looks amazing!!!
rick201830 Aug 2019 17:26
@Steffen80 On our exterior, we are also installing a curtain wall facade (Aluminum Cubond) with a concrete look.
The ceramic panels are probably Eternit. It’s somewhat more affordable than other options.
@11ant The parcel mailbox will be installed in the recess/corner of the retaining wall.
