Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
Bookstar
13 May 2021 14:57
rick2018 schrieb:
@k-man2021
You’re mistaken about the wall construction.
The precast concrete cavity walls are filled with concrete on site, so there is no cavity insulation. However, there are cavity walls with insulation. That didn’t work for structural and other reasons. The main reason was our floor-to-ceiling windows that extend to the ceiling. Each pane weighs nearly 2 tons…
With “normal” windows, we would have chosen that method.
Now we have a ventilated rainscreen facade with mineral insulation.
So with “normal” windows, you can skip that.
Every elevator has specific shaft dimensions. Retrofitting one is very complicated. I don’t know anyone who has ever activated the planned shaft. Either install it right away or don’t bother. Please keep in mind that the bureaucracy around elevators can be annoying. You must comply with all requirements at least for commissioning: emergency call system, access, mirror, inspection, emergency plans, elevator attendant… Maintaining this is expensive. If you don’t, you’re liable in case something happens to a third party (e.g., a cleaner). Most people I know disable the emergency call system anyway since nobody comes into the building. And they can’t shut down the elevator because they have no access. They just leave it inactive…
We don’t have a residential-type elevator. Generally, elevators with hydraulic drives are not used for low-frequency operation. These constantly position at a defined floor level, meaning pumps run continuously and maintenance is more complex. Instead, elevators with electric motors and belts are used.
Of course, there are also safety doors for elevators, but I don’t quite understand the question. Our elevator is inside the security zone within the house.
There is a very secure door from the garage to the house. All areas are furthermore monitored with motion detectors, presence sensors, and cameras. This area is the most vulnerable since a garage door provides very little security.
I can’t give you an exact figure. It’s roughly around the KfW 55 standard. Actual values are not yet reliably available.
What you use to heat the house doesn’t really matter. We could also heat our house with wood or electricity.
Do you happen to have a tunnel plan like the one in Money Heist? I need to figure out how to get underground to the pool party if the invitation doesn’t arrive. :P
Harakiri
13 May 2021 15:10
@k-man2021: If you later face similar structural challenges as Rick, and if you’re brave enough, you might consider using double walls made of carbon concrete reinforced with fiberglass rebar. This allows you to carry much higher loads with similar wall and bearing plate thicknesses, or conversely, to build significantly slimmer structures. However, this technology is still under development (especially in the single-family home sector).
If you also insulate the cavity with Slentite, you’ll (probably) have no budget left for an elevator, and thus one less problem. 😉
k-man2021
13 May 2021 18:37
rick2018 schrieb:
You’re mistaken about the wall construction. The concrete hollow core panels are filled with concrete on site. So, there is no cavity insulation ... weight of a single panel is nearly 2 tons…
Great, thanks, I understand now. We’ll probably need some kind of sky frame or similar as well... but not necessarily in resistance class BR7 😉 ... we’ll see.
rick2018 schrieb:
Every elevator has specific shaft dimensions. Retrofitting is very complicated. I don’t know anyone who has ever activated the intended shaft afterward. Either install it from the start or not at all. Please keep in mind that the bureaucracy around an elevator will be frustrating. You must (at least for commissioning) meet all requirements, such as emergency call system, access, mirrors, inspections, emergency plans, elevator attendants... Maintaining this will cost a lot of money. If you don’t, you’re liable if anything happens involving a third party (e.g., cleaner). Most people I know disable the emergency call since no one is actually entering the building. And they can’t shut down the elevator because they can’t access it. They just let it sit idle...
Our elevator is inside the building’s secure area.
Thanks, that’s valuable information! I wasn’t clear about the elevator, but you answered my questions: your elevator is within the secured area and does not itself provide access, just like the garage door.
rick2018 schrieb:
What type of heating you use doesn’t matter.
Actually, it does... no gas here, and our land is in a water protection zone, so deep drilling is prohibited. That means only ground collectors remain an option, but they are limited or constrained by existing buildings and vegetation. But that’s a topic for a separate thread...
rick201813 May 2021 18:45
Heat pump, pellets, gas tank… there are many options.
I hope you know the prices for Skyframe and similar products. Ours are from Swissfinline.
You can easily pay 10 times more than for "standard" windows.
Soon there will also be a major photo shoot here for the reference projects….
k-man2021
13 May 2021 19:12
Yes, I can imagine that. We also don’t have standard windows and ours have a high resistance class... It doesn’t have to be SkyFrame everywhere in our case either... and if the elevator is removed, as @Harakiri suggests 😎, maybe the budget will allow for one more window...
rick201813 May 2021 21:17
What is your approximate budget?
