Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
stekna
11 Mar 2021 21:30
@rick2018
Thanks for your feedback. I have one more question about your pool. We are currently undecided between a Paradiso sliding roof and polycarbonate slats. With the Paradiso, I’m concerned about the tile bonding. For the slats, people often advise against them because of dirt buildup and the supposed “unsightly” appearance after a few years. Have you gained any experience regarding dirt accumulation?
rick201812 Mar 2021 08:17
@stekna We have an infinity pool, so a sliding roof was never an option. I also don’t like the look, and you need space to slide it open. However, it still makes sense to have a cover on the water.
Our advantage is that we have almost no biomass entering the pool. I simply open the (floating) cover. A few leaves end up in the pool, which I either pick out while swimming or the robot cleans up.
If there is a lot of debris on it, you can also use a leaf blower or garden hose to remove it (the debris then falls over the edge).
The polycarbonate covers are easy to clean with a pressure washer or brush. This only needs to be done once a year. It’s important that they are always kept in the water or protected from sunlight.
Ours is a polycarbonate solar cover that rolls up into a hidden pocket underwater, so nothing is visible.
I would definitely do this again. Even covers that are several years old still looked great.
Cheaper PVC covers are more problematic and prone to damage.
Even with minimal maintenance, you will enjoy a polycarbonate cover for a very long time. The rest of the pool actually requires more effort, even if most of it is automated.
k-man2021
10 May 2021 16:04
@rick2018
I’m new here and have spent the last few days reading through about half of the thread – really impressive what you have planned and, above all, accomplished!
We decided a while ago to build again, and also a Bauhaus-style house – probably a smaller version, but in terms of appearance it could look similar to yours.... There is one question that concerns us, namely the architect. Unfortunately, I don’t have a friend who is an architect and also likes Bauhaus :-(
When we look for architects who have designed houses we like, we either find them in southern Germany/Baden-Württemberg or Belgium, but unfortunately we are building in Hesse. Did the same firm that did your design also supervise the construction on site, meaning all project phases? Based on your experience, do you think it’s possible to split these services?
rick201811 May 2021 06:37
@k-man2021 First of all, welcome to the forum and good luck with your project. Please share updates here as well.
Most of our work was done by a single contractor. Some trades were managed directly by me.
It is possible to split the work, but the contractors should not be just any run-of-the-mill company; they need to be familiar with the materials and so on.
Our house is connected, very detail-oriented, and has several special features. It wouldn’t have worked without me being on site almost every day (usually all day). I also did some of the work myself.
Are you planning to build with concrete? Consider opening a thread where you present your dream home.
Bauherr am L
11 May 2021 08:24
From personal experience: Rick is right. A high level of personal involvement is necessary, especially when you have elevated desires and expectations.
It might also depend on the architectural firm. If you have one that regularly designs such demanding single-family homes, you could at least expect them to manage the process well.
In our case, the architects were often overwhelmed—unfortunately also on a technical level. As a result, things were chaotic. At times, I even had to explain the correct handling of building materials on site—particularly in the area of waterproofing (both above and below).
My personal recommendation: choose your architectural firm very carefully. These are the people on whom most of the success depends and who will affect whether you have restful or restless nights. Those with higher demands need to hire professionals accordingly. Looking back, I would also be willing to pay more for this. Don’t just focus on attractive designs but also on whether the firm can manage construction sites professionally and technically without gaps.
bortel
11 May 2021 08:53
I think these might fit... sorry @rick2018
Engelshove Bau GmbH
