Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
pagoni2020
9 Jul 2020 00:09
Müllerin schrieb:
Great, still not really my style but definitely a visual highlight. The panes look quite reflective – how do you deal with the issue of bird collisions?
That doesn’t really happen, or at least not any more than anywhere else… it’s better to skip the plastic bird decals.
Ideensucher
9 Jul 2020 00:51
Müllerin schrieb:
The glass looks quite reflective; how do you deal with the issue of bird strikes?
I assume that if anything, the birds have the problem with the glass, not the glass itself. The rest is taken care of overnight by the fox.
Very interesting and impressive house. Somewhere in the 150 pages you wrote, "we had to make compromises as well." You have some quite unique features, for example your asphalt screed.
Could you maybe share what you would have done differently if you had allowed the build to cost 10% more? (I deliberately don’t write "could spend 10% more" – I would find your answer all the more interesting).
bortel
9 Jul 2020 06:04
The facade is not to my taste, but everything else is simply amazing!!!!
rick20189 Jul 2020 06:25
@11ant: No idea. A standard insurance policy doesn't cover this. Better to set aside a reserve fund and replace it if a defect occurs...
@Müllerin: Bird strikes shouldn’t be a problem. The panes are not mirrored. My mother has a large conservatory and feeds birds year-round. In the first year, there were a few strikes. Now there aren’t any. Only when young birds are around does one occasionally hit the glass. Rarely with fatal consequences.
@Bauherr am L: Cavity insulation was not possible due to the glass system.
@Ideensucher: The poured asphalt floor isn’t really more expensive. You save on screed and floor covering. However, this requires a metal underfloor heating system…
We splurged on some things, like the glass system, the ceilings, etc., which significantly increased costs.
What I would have done, if money wasn’t an issue (before construction started):
- Solid concrete, thick enough to require no insulation. Preferably with a company from Switzerland. After seeing the result, I wouldn’t consider this anymore.
- Property boundary: retaining wall buried in the ground and finished with natural stone and corten steel in visible areas. I asked for an offer but declined politely.
- Possibly made more glass elements motorized and movable.
- Installed shower-toilets everywhere from the start.
- Terrace flooring in a very large tile format.
- Lifting floor for the pool.
- Flocculation system for the pool.
- Larger elevator.
- Possibly a kitchen from a different manufacturer.
- Also plaster and paint the technical rooms to Q3 standard and install flooring.
- Insulated and centrally heated pool pavilion.
Many decisions were made with maintenance in mind. I don’t want to constantly check, clean, or refill here and there… nor do I want permanent staff in the house.
We already have much more than we need.
Alessandro
9 Jul 2020 07:18
I’m looking forward to the interior work and the furnishing (if you want to show that).
I just like everything about the project!
Bauherr am L
9 Jul 2020 09:11
@rick2018
- What kind of kitchen do you have or are you going to get?
- By "solid concrete," do you mean something like lightweight concrete that provides insulation and structural support at the same time? I read something about that a while ago from a homeowner in southern Germany. He is also an architect and built his house using that method. I think it’s really cool, but you definitely need a specialist or architect who knows about it. The walls also end up being quite thick.
What I’m generally wondering is how the Swiss manage to achieve such high-quality exposed concrete both inside and outside while keeping it relatively affordable. I’m thinking of the architects Marte Marte as an example. By the way, who is your architect, or is that confidential?
