Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Now a bit about me:
tumaa schrieb:
There are lesbians, but the majority of women are straight... so what?! And now the chauvinistic stereotype is thoroughly confirmed: assuming "woman and not technophobic" means lesbian :-(
@superzapp
There are 6 patch panels with 24 ports each, probably not fully populated. About 10 more cables will be added. These are strictly network cables, so nothing misused for KNX. The house and property aren’t large enough to have cable runs of 100 meters (330 feet). Around 60 meters (197 feet) should be the maximum. The distance to the office is considerably shorter, so 10 GbE won’t be an issue.
The cables were already labeled pretty well by the electrician by hand. There were only a few cables where I needed to double-check. Now, with the right printer, the installation cables are labeled with position/function and the patch panel plus port. The router and switch are programmed accordingly. Patch cables are labeled as well—pretty meticulous. I don’t want to have to search later. Since this is not a dynamic setup, I can basically define everything fixed.
I’ll move the cabinet in next week. It will be placed right next to the cable tray in the middle of the room, so I can access it from all sides. If I don’t like that, it will go underneath to the side. It has enough cable entry options (Stengel cabinet). It is also a double-depth cabinet. With my equipment, that’s no problem (thermally and with opposing fans…). There’s still plenty of room inside.
The floor will remain as is. It might get coated later. If it stays raw, there will be fewer discussions about floor space regarding property tax...
Yes, at the back wall is the Unitymedia connection (now Vodafone). Since I don’t need a telephone comfort option, they provided the annoying (new) Vodafone Station. It was planned anyway to replace it regardless of what they supplied. The station is located in the locked outdoor box at the back right. During construction, it provides Wi-Fi for the workers and me. Mobile reception on the property is poor and nonexistent inside the building.
I already have the power upload and native Dual Stack.
The Telekom connection is also there, though with a max of 12 Mbit/s download and 2.5 Mbit/s upload 🙄.
There is also an empty conduit in case fiber optic is installed in the future.
Thanks for the compliments. I’m tech-savvy and quite proficient for a non-professional. But connecting modules isn’t that complicated; you just need to be careful. Part of it will be done by the electrician; I’ll handle the patch panels. All cables will be tested and documented at the terminations.
My TC4400 with the latest firmware (.42) was delivered within 30 minutes. I’ll play around with it in the next few days. I won’t provision it until my server rack is fully installed.
rick2018 schrieb:
There are 6 x 24-port patch panels. Probably not fully populated.Still: why are they all yellow? - Color coding helps with organization.https://www.instagram.com/11antgmxde/
knalltüte2 May 2020 15:1711ant schrieb:
Still: why are they all yellow? – color helps with organization.... this is usually not done. Otherwise, the electrician would have to buy two different 1000m (3280 feet) rolls... It’s custom-length cable that you don’t just change the color of. Also, not every manufacturer offers every quality in every color. Is that Leoni Yellow cable rated for more than 1000 MHz?
The patch cables are probably color-coded according to their function – right?
@11ant These are the installation cables.
They are connected to the patch panels.
There are hardly any other colors unless the cables are specifically fire-resistant or are only CAT 5 or 6, etc.
The patch cables are then colored. Additionally, everything is assigned within the software.
