Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201813 Apr 2020 14:07
Since I spread the work over several days (2-3 joints per day), it went smoothly without any mistakes.
rick201814 Apr 2020 15:35
Today, work began on the floor. Since this is not very common, I will gladly share a few pictures.
I already described the process a few pages ago.
The whole crew was on site punctually at 8 a.m. Due to the complexity, a team of 12 people is currently working.
They also brought the inclined lift and the first truckload of asphalt.
Large pink concrete mixer truck stands on a construction site next to scaffolding
The inclined lift is used for the balcony on the upper floor. Inside the house and later to the lower levels, the transport is done manually as before.
Construction worker carries two buckets of mortar; floor with copper pipes and metal plates.
Several construction workers carry a bucket of concrete on a long wooden pole during interior construction.
The over 200°C (392°F) hot material is poured and spread, smoothed, etc., using a piece of wood.
It is tough work. Besides the weight and temperature, there is also the smell. In the past, asphalt was heated even more, but this is no longer allowed for several reasons.
Currently, this is the first layer to bond the installation at the floor level.
Two construction workers lay copper pipes for underfloor heating and spread black sealing compound.
The goal is to finish the first layer by tomorrow evening and the second layer by the end of the week.
The garage will be completed much later since we need it for storage, and the specialist for the preliminary work cannot come right now.
Climbee14 Apr 2020 16:26
Very exciting! As I said, it's not quite my style visually because it’s too dark, but I’m not familiar with this type of flooring at all, so I’m curious to see how it will turn out in the end.
Do they actually bring them in with those old-fashioned wooden buckets on the yoke? That’s probably the only material that works well with the asphalt, right? But somehow it looks like it’s from another era...
rick201814 Apr 2020 16:56
This is just the bottom layer. It is the same asphalt that is sometimes used in renovations.
Only after the second layer and sanding do you see the final result. However, it still might not suit your taste.
We will have the wood on the ceiling afterwards.
It remains the only way to process it. Only transportation and heating have become more modern. The last meters and installation are still the same. #HardWork
hampshire
15 Apr 2020 09:51
Actually, the combination and placement of the materials (hard/rocky on the floor and wood on the ceiling) feels quite natural. The only thing missing is the foliage.
I believe that the floor, in interaction with the building, will suit my taste very well, even though we chose a completely different type of house ourselves.
I had concerns about bringing any materials with strong unpleasant odors into the house, which was a deciding factor for us. Whether it is truly healthier, I cannot prove and won’t even try – the decision was made based on emotional reasons, and that’s that.
What I particularly appreciate about your project is the clear respect you show towards your craftsmen.
rick201815 Apr 2020 11:31
@hampshire I understand your concerns, but the smell disappears after cooling down and a few days.
Here is an excerpt from the Building Biology magazine:
“Cast asphalt screed is a bitumen-bound screed. A filler mixture of stone dust, sand, and gravel in approximately a 1:2:2 ratio is combined with about 8% bitumen as a binder in hot form, mixed thoroughly, and poured in at around 250 degrees Celsius (482°F).
Cast asphalt screed offers several advantages: it is water-free (so no moisture is introduced into the building), provides impact sound insulation (low longitudinal sound conductivity due to its ‘rubber-like’ behavior), and can be walked on and covered after just a few hours.
Although the binder bitumen is derived from petroleum, it should not be confused with tar binder, whose emissions are considered highly hazardous to health.
During the hot phase, such as during installation, health-hazardous emissions from the bitumen content can occur. Therefore, protective measures according to technical regulations must be strictly followed.
In its cold state, however, no significant toxic emissions are known. Installed cast asphalt is therefore not considered harmful to health based on current knowledge.”
So, from a building biology perspective, we have no concerns here.
